Old 09-04-2018, 12:53 PM
findane findane is offline
Default spring loaded oil door
There was a company called Justrvparts use to sell a spring loaded oil door. Anybody know where they are and if they're still making the door?
Dues paid for 2019
Old 09-04-2018, 01:16 PM
pilotkms pilotkms is offline
Default Aircraft Spruce
Search “oil door spring”. Both the spring and the hinge will appear.
Keith
RV 7A RV #9700 May 2017
N325KS the Flying “K”
Built in SoCal KCCB, now @ KPXE
270+ Hours & 5x cross the USA
2018 OSH - yes
Old 09-04-2018, 02:58 PM
Bavafa Bavafa is offline
Cleaveland tools has one that is pretty nice. I have used it in my old 7 and now on the 14. It has a spring that will pop open once unlocked. You will know it before flight if it is not locked.
http://www.cleavelandtool.com/Oil-Do.../#.W47xbq_rupo
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 09-04-2018, 04:53 PM
starkw1 starkw1 is offline
Default Spring loaded oil door
I used the spring from as mouse trap on my oil door.
Works fine.
Warren
RV-7 N671CW
Plymouth, MN
Old 09-05-2018, 12:50 PM
Thanks forthe replies. I googled a variety of combinations of "oil door" and "spring" but it's not what I was looking for. I saw an oil door that was spring loaded where you pushed down to open and the oil door would spring back closed. It was a compete assembly. Sold by a company called Justrvparts. I can't find any information on the company
Dues paid for 2019
Old 09-05-2018, 01:11 PM
akarmy's Avatar
akarmy akarmy is offline
Here is the one I used. It both eliminates the hinge eyelets from view on the outside of the cowl, and gives a spring to open it. I then used an aluminum door and some bent angle to stiffen it. The door is held in place with a single hartwell latch.
http://www.cleavelandtool.com/Oil-Do.../#.W5Apg5NKg8s
Andy Karmy
Covington WA
RV-8 - Flying!
RV-9A - sold
Nov 2018 Paid
Old 09-05-2018, 01:24 PM
BillL BillL is offline
What Bavafa and Andy have linked to is what you are asking for. The waybackmachine has the web site but no pictures. The description is the hidden hinge that Cleaveland tools now carries.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Shrunken Exit = ??
No Photo? => PM me.
Old 09-05-2018, 03:33 PM
Sounds like he's looking for a door that opens inward, not out, and the spring shuts the door. I've seen them, but would say that you need to be sure the door will clear the fill tube and any other structure before committing to a design like that.
