dan
I'm interested in finding out how many people have had to swap out their oil cooler for a different (typically better and/or larger) one at some point.
If your answer to the poll is YES, it might be helpful to list:
- typical temps (peak & cruise) before & after
- aircraft model
- engine type
- ignition type(s)
- compression ratio
- oil cooler installation details
- any relevant changes you made along with the swap-out
- etc.
- aircraft model
- engine type
- ignition type(s)
- compression ratio
- etc.
