Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
Old 07-18-2018, 10:11 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post Garmin GTN 6XX/7XX Descent Vertical Navigation, July 18, 2018
August 29, 2018 update: GTN software version 6.50 released today. If you have an E-AB aircraft, you can install the new software per Service Bulletin 1859 from the Garmin website: https://www8.garmin.com/support/coll...=155&pID=63892
There are three different links on the download page for Service Bulletin 1859. The first link is the Service Bulletin documentation. The second and third links include the software files. Please see the Service Bulletin documenation for complete details and make sure you are familiar and comfortable with the software update process outlined there before attempting it on your own aircraft. If not, the option of seeking assistance from a dealer is still available.
Full integration of the VNAV feature with the G3X Touch will be available in GDU 4XX software 6.20. We are in the process of testing the software now and expect it will be available in September.
The primary new features are listed below, please see Service Bulletin 1859 for a complete list of changes.
Garmin G5 and G3X Touch systems have always had coupled VFR VNAV capability to use the autopilot to perform functions such as descend from cruise altitude to pattern altitude, but up until now, we have not had the ability to use coupled VNAV when using the GTN navigator.
With GTN V6.50, pilots can take advantage of VNAV profiles throughout the enroute and terminal phases of flight within the GTN 6XX/7XX touchscreen navigators when they’re paired with the G5 or G3X Touch system. Within the GTN, pilots can easily enter altitude constraints on the flight plan page to set-up a vertical descent profile. Pilots also experience a near-seamless transition from VNAV to an arrival and instrument approach. Once an arrival or approach is loaded and activated, the GTN automatically populates step-down altitudes or any applicable altitude restrictions. If ATC issues an unpublished altitude restriction, pilots can enter those altitudes manually into the active flight plan under the VNAV field.
Here is an example of this flight plan page on the GTN 625.
As part of the VNAV profile, top of descent (TOD) and bottom of descent (BOD) values are also calculated and displayed on the GTN moving map. As the aircraft arrives at TOD, the GTN displays a visual annunciation prompting the pilot to begin the descent. The G5 or G3X Touch display will provide a vertical deviation indication (VDI) to provide vertical guidance for the descent.
When a G5 or G3X Touch autopilot is installed, pilots can select the VNAV button on the mode controller (or touchscreen) to fly a fully-coupled VNAV profile.
We are also pleased to announce that the GTN 6XX navigators have a new full size QWERTY keyboard available to improve data entry with this GTN software release.
These GTN software updates are expected to be available from Garmin in August at no charge. A dealer installation charge may apply, but as in the past, we plan to make this software update available as a download to customers with non-certified aircraft.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 07-18-2018, 10:24 AM
I will have to check this out more when i have some time, but this sounds great. Thanks for the update.
rockwoodrv9a
Williamston MI
rockwoodrv9a@gmail.com
O-320 D2A
Awaiting DAR Inspection
Old 07-18-2018, 10:37 AM
RONSIM's Avatar
RONSIM RONSIM is offline
Smile Wonderful -- the only reason I envied my 750
brethren was because of the full keyboard. (actually I envied other aspects of the 750 but panel space and dollars preclude the 750)
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 07-18-2018, 10:48 AM
bkthomps bkthomps is offline
finally! thanks for the hard work garmin, this will be very helpful around bravo's, are the TOD and BOD graphics planned to be integrated to the G3X at any point? or will we just see the banana trying to update against current vertical speed
Old 07-18-2018, 11:04 AM
HSANTIBANEZ HSANTIBANEZ is offline
Steve
Hi Steve, why you talk only about g3x touch? y have the legacy and also have vfr vnav with autopilot if the waypoint have altitude and obs in gps in the gtn.
Hernán Santibáñez
Valparaíso, Chile
RV-7 TMX-IO-360 G3X and VPX Flying over Chile
2018 Dues Paid
Old 07-18-2018, 11:27 AM
Captain_John's Avatar
...similar question to above, would adding G5 to a legacy 37X system allow VNAV functionality?
CJ
P.S. love the querty keyboard!!!
Old 07-18-2018, 11:49 AM
g3xpert's Avatar
Post
Hello Brian,
Good question. At least initially, we don't expect the TOD/BOD information to be shown on the GDU map since this information is not currently available from the GTN.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 07-18-2018, 11:54 AM
g3xpert's Avatar
Post
Hello Hernan (and CJ),
Another good question. We have wrapped up the changes to support this new GTN capability in the G5, which is used both in EAB installations and with the GFC 500 certified autopilot, and are currently working on completing this integration with G3X Touch (GDU 4XX).
After finishing this work we plan to look at whether or not we are able to offer this capability to GDU 37X customers. We haven't ruled this out.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 07-18-2018, 12:00 PM
digidocs's Avatar
digidocs digidocs is offline
One word---sweet!
Old 07-18-2018, 12:16 PM
Jasonm Jasonm is offline
THANK YOU GARMIN!!!
Sorry for the CAPS, but this is great news!!
Jason McKay
"Phase 1 - 05/26 - 07/02"
2017 Dues Paid
