Old 07-01-2018, 05:40 PM
rvator4twa rvator4twa is offline
Default Intermittent elevator trim
Had a flight with elevator trim inoperable. Tried a bigger fuse and worked again. After it quit again, I examined the area and discovered the threaded bar between the trim tab and trim motor was catching sometimes on the threads. Used a dremmel to lengthen the slot and problem is solved.
Ron Burnett N524RB
RV-6A Lycoming O360 dual EFII
M71-Greensfield, MO near St. Louis
Dues gladly paid Nov. 2018
Old 07-16-2018, 10:02 PM
Thought extending slot for trim tab push rod fixed problem but not for long. According to Gary at Ray Allen, I need a new trim relay and to test it he said when access is available, tap the relay to see if it works. Sure enough. I only have 250 hours on airframe but new replacement relay is beefier.
Ron Burnett N524RB
Old 07-16-2018, 10:56 PM
Ironflight's Avatar
VAF Moderator / Line Boy
This is a well known problem with older Ray Allen relays. Very common years ago. I think they must have changed the design, becasue I haven’t heard of any recent failures in newer installations.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 07-17-2018, 08:54 AM
Default Trim relay
True Paul. I had the relay deck 1 and am installing deck 2 which looks over twice as tall. Expect to not have that issue again.
Ron Burnett N524RB
