Old 06-26-2018, 08:57 PM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
Default RV-10/14 Flap Actuators are here!
We are now ready to ship our new RV-10/14 Flap Actuators.
We have four RV-10s out there with our new actuators and we are pleased with the results we have seen so far, especially in the RV-10 in which we installed our actuator here locally.
Here is a thread with one builder's experience:
http://www.vansairforce.com/communit...=flap+actuator
Again, these actuators are an upgrade over the factory flap motors in that they stop when they get to the end of their stroke (standard 5"), they have internal position sensors, and the safety-wire service bulletin is not required. Extension/retraction time is about 12 seconds, same as the stock units.
Please compare the price of our actuator with the stock flap motor, which just might be the best feature of our new product!
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Helped build Bob Lund's airplane)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com/blog (Photography)
Track Me
Old 06-26-2018, 09:31 PM
Default Flap actuator
I have one of the actuators that I retro fit. It was straight forward and worked out great! The actuator is definitely a well built unit and is very smooth when operating...AND... it has a position sensor BUILT IN!
This is an AWESOME upgrade and Pat is GREAT to work with!
Highly recommended...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Dues Paid 2017,...Thanks DR+
Old 06-27-2018, 07:27 PM
CubedRoot's Avatar
CubedRoot CubedRoot is offline
Hey Pat,
Any chance you might consider selling a version for the RV-7's as well?
Lynn Dixon
RV-7 Slider -
Tail kit Completed - March 2017
Wing Kit Started - June 2017
My Build Log: http://www.theskunkwerx.com
VAF Donation paid for 2017
Old 06-27-2018, 07:57 PM
I got the flap system from Pat for my 9A and it went in very easy. It should fit for the 7 as well. It was a pleasure to take the ramp with the RA sensor and throw them on the workbench!
I haven't gotten the wiring or the set points done yet but only because I have been out of town. Pat was great to work with and has offered me help if needed.
rockwoodrv9a
Meridian Idaho
rockwoodrv9a@gmail.com
O-320 D2A
Awaiting DAR Inspection
Old 06-27-2018, 08:01 PM
Pdtofly Pdtofly is offline
Default Flapp Acuator for RV-7
Lynn,
Here is the same type of acuator for a 7. The cost is only $129.95. It also has limit switches, and a pot for position display in your EFIS.
https://www.pololu.com/product/2305
The mount is only $17.95
https://www.pololu.com/product/2314
There is a hole drilled on the end, but going the wrong way. What you do, is unscrew the end from the motor assembly, and put it in a lathe and center drill it, tap and mount your rod end.
As for mounting to the RV, it is also not a direct replacement, but easy to modify.
For anyone else, you can use this same actuator on the 4, 6, 7, and 9.
Good luck.
Old 06-27-2018, 08:02 PM
Default Flap Acuator for RV-7
Lynn,
Good luck.
Old 06-28-2018, 04:52 AM
Pat Hatch's Avatar
Originally Posted by CubedRoot View Post
Hey Pat,
Lynn, Sure! They're available now, check out the web site. Here's a thread with one builder's experience in the RV-7:
These actuators were made specifically for the RVs with the correct stroke length, torque, and speed for that model. Thanks for your interest.
Pat Hatch
RV-7 (Sold)
Track Me
Old 07-02-2018, 07:01 AM
rleffler's Avatar
rleffler rleffler is offline
I just finished installing one in my RV-10 this past weekend.
It took me 4-5 hours to fabricate the new mounting brackets and get them installed.
The installation was simple and straight forward. Updating the flap settings in the VPX/Pro just took a few additional minutes.
Constantly having to re-adjust the Ray Allen Position Sensor due to slippage over time and the flap motor not shutting off at full travel (which in turned trips a breaker) were the key motivation for the upgrade.
The product works as advertised, you can't ask for more. Also, Pat has been extremely helpful answering all my questions during the process.
PHAviation definitely gets a thumbs up from me.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 07-02-2018, 07:23 AM
Default Photos
Todd,
I have a bunch of photos of the retrofit if you want. It amounts to removing the Vans actuator, then fabricating a couple of angles to move the pivot point further forward.
I can email the pix if you want, just tell me where to send them.
Pat is awesome to work with!
Bob
Doors - Done
On Gear
290 HP Barrett Hung
Old 07-02-2018, 07:28 AM
Auburntsts's Avatar
Originally Posted by rocketman1988 View Post
Todd,
Thanks, but no need. After I posted that pic request (which I deleted) I found the install manual on the PHAviation website which clearly shows what's required.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
