Old 06-25-2018, 12:11 PM
Drippy Drippy is offline
Default bi-fold door repair
OK this isn't an RV10 question but I was wondering if anyone has replaced a cable on a bi-fold hangar door. I am in a rented hangar and one of the 3 braided steel wires is fraying and looks like it will be going soon. It looks to be as simple as replacing it and making sure to get the length right so it is balanced with the other two lift locations but figured I should ask.
Thanks up front
Mike
N95VT
RV10
~150hrs flying
Old 06-25-2018, 12:42 PM
ppilotmike's Avatar
Mike,
If you're in a rented hangar, I think you should have the Owner fix it before it potentially becomes your problem (i.e. falls on your plane, you or your guests). If you try to do it yourself and it fails, you are on the hook; especially if you did the repairs without the knowledge/permission of the Owner.
Mike Rettig
EAA Chapter 301 www.eaa301.org
VAF Dues Current: Paid for 2019 on 12/03/18
RV-10 (41PX Reserved) Fuselage
http://www.mykitlog.com/users/index....ig&project=803
https://www.youtube.com/watch?v=zKCyX2FXrlw
Old 06-25-2018, 06:14 PM
Default BI-fold
Mike,
Yes the owner asked me to make the repair but you make a good point.
Mike
N95VT
RV10
~150hrs flying
Old 06-26-2018, 10:13 AM
Jpm757 Jpm757 is offline
I agree the owner should be responsible for the repair. But if for some reason you wind up having to do the fix then it is pretty straightforward. I would replace ALL cables while you are at it. Place cinder blocks on the floor under each cable and lower door until cables are slack. Replace one at a time and adjust tension evenly.
Jake
RV6 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 200+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600.
1941 J3 Cub skis floats.
2019 dues gladly paid.
Old 06-30-2018, 05:49 PM
Nukeflyboy Nukeflyboy is offline
Default Bi-fold repair
Cable replacement is easy. Call the mfg and they will help with what you need to order. Measure the cable lengths and door height before you call and have the serial number ready.
Dave Moore
Granbury, TX
RV-10 and Breezy
Old 07-06-2018, 03:01 PM
Default Complete
Thanks for the cinder block suggestion.
Repair complete as you stated pretty easy. Worst part was we were having our annual heat wave here in Vermont and working in a closed up hanger at 100F wasn't a lot of fun for a guy who still hasn't lost all of his winter insulation:-).
Mike
N95VT
RV10
~150hrs flying
