Old 06-19-2018, 05:49 PM
azflyer21 azflyer21 is offline
Default First time fiberglass work a success
I was very intimidated with the fiberglass work. I following the plans for the fairings and I am very satisfied with the results. This builds a little confidence for the upcoming windshield fairing.
Kevin Lippert
Zenith 750 completed 2016 -
Sold
N902X reserved
RV-14a Empennage Done
QB Wing QB Fuse inprogress
Build Log
Old 06-19-2018, 06:51 PM
Davoakes@att.net Davoakes@att.net is offline
Nice job!
Keep up the pace and it will be finished before you know it.
I am not quite there yet, half way through the tail cone. All others pieces except fiberglass done.
Daveoakes
RV-7A N1243A Sold
#140479 RV-14A N1479B Reserved
Old 06-24-2018, 11:24 PM
wjb's Avatar
wjb wjb is offline
As others have said: "with fiberglass, nothing is permanent" With aluminum, drill a hole wrong and it stays wrong. With fiberglass, just fill and try again! It is a very flexible, if not messy, medium. A few boxes of rubber gloves goes a long way.
A good quality scale is very helpful. West System epoxy mixes 5.36:1 resin:hardener by weight. I picked up a 0.1 g digital scale from the aviation section of Amazon, and now measure all my epoxy by weight (tho, the West System pumps do a good job as long as they don't get an air bubble). The stuff sets up perfectly every time this way.
Bill Bencze
N430WB (reserved) RV-7 #74152, tip-up. Engine hung!
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2018 donation happily made
