Old 06-13-2018, 12:27 PM
Av8torTom's Avatar
Default Input Needed
Hello - I'm starting to think about the layout of my panel. Will be VFR, day/night. I'm thinking one 10" and one 7" Dynon, but not married to any manufacturer at this point. Input greatly appreciated. Also, where are most people placing their main electrical bus in the 9A?
RV-9A (empennage completed, both wings completed, fuselage and finish kit completed, engine hung, working on panel and wiring)
N677AT reserved
Superior XP O-320, 160HP
Old 06-13-2018, 12:43 PM
It would appear you are using a keyed ignition/start switch.
They are kinda bulky----so be sure you leave adequate room around the body of the switch.
Your breaker grid might need more room for vertical spacing, due to size/shape of the breaker body.
Xpnder?
Old 06-13-2018, 12:47 PM
Av8torTom's Avatar
Default Thanks
Hey Mike thanks for the heads-up.
I was thinking of the Dynon transponder module. I believe it interfaces thru the EFIS?
N677AT reserved
Old 06-13-2018, 12:50 PM
Carl Froehlich's Avatar
What I would do:
- Move the airspeed and altimeter steam gauges to above the radio stack, side by side, airspeed on left.
- Move the left 10” SkyView display further to the left.
- Move the radio stack to the left, just on the right side of the left display.
- Add the SKyView knob module under the left display, or under the intercom module (the best money you will spend on the panel)
- Replace the 7” right display with anther 10” SkyView display, just to the right of the radio stack. Normal use for the right display tends to be engine monitoring and the map “Scratch Pad”. This is the map that I use to look out for weather, get weather reports, look for TFRs etc. It is also big enough to be the primary display for the pilot, and makes flying in the right seat easy.
This is about what I have in the RV-10 (second panel integration) and it works well. If I changed anything, I’d leave out the altimeter (but keep the airspeed). I find I never use it. I do use the round airspeed for take off and landing.
Old 06-13-2018, 12:54 PM
The Dynon SkyView XPDR is a no brainer. Good price, does TIS on the primary display, and configuring for ADS-B out compliance is simple.
The transponder integrates seamlessly with the SkyView.
Old 06-13-2018, 12:58 PM
Kinda figured that, just checking to be sure.
Old 06-13-2018, 02:52 PM
If you're married to breakers (I'm not), wiring the hot 'buss' is a bigger project in a 2D array than a 1D array (line). And orders of magnitude more expensive than ATO fuses, but that's an individual choice.
Old 06-13-2018, 03:12 PM
sglynn's Avatar
sglynn sglynn is offline
Default Panel
Hi, I just did my panel with Dynon HDX and D6 for backup EFIS and Garmin 430 for legal IFR.
If you are VFR only I would not bother with any backup steam gauges. The HDX is all you need. You really don't need a second screen.
You might check out audio panels by PS Engineering. They have have some cool features and are not too expensive.
Steve Lynn
RV-7A
100% Complete
Airworthiness Certification Complete
First Flight in January 2018
Anacortes, WA
www.mykitlog.com/sglynn
Old 06-13-2018, 05:14 PM
Av8torTom's Avatar
Default Thanks everyone
Thanks for all the input.
I'm still looking for advice for the lest place to locate the main electric bus
N677AT reserved
Old 06-13-2018, 05:47 PM
sglynn's Avatar
Default VP-X
I would use VP-X. I did use the equivalent red box from Advanced Systems. These are power distribution and switching boxes that also provide circuit breaker functionality. I mounted it right behind the HDX screen on the subpanel. If necessary I can access it by removing the big screen.
Steve Lynn
RV-7A
100% Complete
Anacortes, WA
