Old 06-12-2018, 11:34 PM
crabandy crabandy is offline
Default Cowl flap thoughts
I think Iíve seen/googled most of the ideas out there when it comes to cooling the lycoming in the summertime. Iím sure there are many more out there that I havenít seen. Iíve done a decent amount of work with inlets/plenum/sealing and lastly ignition timing for temp control. Most people seem to be concerned with climb out CHTís. I currently have no issues climbing out on a hot day, I have issues taxiing after a quick turn on a hot day and Iím carbureted. CHTís and oil temps are fine but fuel seems to be boiling, erratic chugging during taxi. Idle mixture is correct and an excessively lean mixture and RPMís above 1000 help.
With my stock cowling I used to see heat radiating out of the upper inlets while fueling. I donít see it with my sealed inlet boots. During ground operations the pressure diff between the upper cowl and lower cowl is very small. How many people pop the oil door open after they land in hot temps?
Most cowl flaps are installed in conjunction with the lower outlet, Iíve stared at this space on my cowling for months trying to come up with ideas. Iíve shrunk and contoured my exit to approximately 35 sq inches, not a lot of room for a cowl flap with a vertical induction carb and 2 exhaust pipes.
Iíve also been staring at the rear of my upper cowling, what about an upper cowl flap, similar to the old 30ís cars/trucks had in front of the windshield? With the low pressure diffs on the ground it would take advantage of convection in addition to a larger exit area during climb out. I kept hoping for an easy test without months of work and downtime.
Iím currently finishing an oil change and making room behind the upper engine mount to possibly add an upper cowl flap when it dawned on me, why donít I spend 2 minutes and remove the oil door and go fly several quick turns? On 4 cylinder lycomings the oil door is behind the upper plenum and part of the lower cowling volume/pressure. Roughly 5x5 (25 sq in) in the upper cowling that is convection friendly on the ground, also pretty easy for anyone else to test fly and and see what kind of cooling the extra exit area gives them.
RV 7 300 hours and counting
12/17 donation
Old 06-13-2018, 05:33 AM
Plummit's Avatar
Plummit Plummit is offline
Just removing the door may not work. I'm pretty sure that part of what makes a cowl flap work is the flap only allowing exit air, which you won't have with just a hole. But by all means try it and let us know what happens!
-Marc
N814RV
2018 Donation made!
Old 06-13-2018, 07:16 AM
Taltruda Taltruda is offline
I used to fly a friends glasair 2rg that had two slots on the upper cowl with a spring loaded door. It souls open and vent off the heat when on the ground but would close itself when ramair in the upper cowl would build up.
Tom
Las Vegas
RV-8 empenage started
Baby Lakes flying
Old 06-13-2018, 07:31 AM
MikeyDale's Avatar
MikeyDale MikeyDale is offline
When I started flying my 7, I always thought something was wrong with my engine. After landing on taxi it would pop and chug! I kept thinking my plugs were fouling! I even bought a set of fine wire plugs to solve the problem (well worth the money by the way but didn't help my problem). I was at 52F one day where Walt was inspecting my Transponder having lunch outside the diner and lo and behold, every RV that came taxiing by was popping and chugging just like mine! Boost pump helps but she's gonna pop when that fuel boils in those injector lines!
Mike Hillger
RV 7 FLYING SINCE 4/2015!
Garden City, Texas
First Flight https://www.youtube.com/watch?v=QqgxhWH3pqA
Build Blog http://mikesrv7.blogspot.com/
Dues Paid
Old 06-13-2018, 10:14 AM
Default An idea...
Many years ago, in one of the experimental aircraft magazine (can't remember which one), there was an article on automatic shutters for the top side of a cowl.
The basis of the design was quite elegant. A set of shutters with moveable doors was installed in the top of the cowl. The activation of the shutter doors was accomplished using the charge cylinder from an automotive thermostat. The plug inside of the charge cylinder expands as it is heated past it's critical temperature and moved the shutter doors to the open position. As the charge cylinder cools, it contracts and closes the shutter doors...
Of course, with modern tech, you could accomplish the same thing using a linear actuator and a temp sensor connected to a small arduino unit...and it would be programmable for any given temperature or time...
These shutters are remade and would do the trick:
https://antisplataero.com/products/o...er-air-shutter
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 06-13-2018, 01:12 PM
PerfTech's Avatar
PerfTech PerfTech is offline
Ö.We have had many customers mount our cowl flaps on the sides of the lower cowl as well as on the top. They report back many advantages, Lower ground operations temperature being one. Another is even lower climb out temperatures, due to the fact that the pressure in this configuration is much lower on top than on the bottom. We have seen most everything possible with flaps on top, sides, bottom and all of the above in one installation. The top mounted location is very popular in Brazil on the RV-10s. Its all good!
Thanks, Allan..
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 06-13-2018, 01:43 PM
Yep, remember that one.
A simpler setup is to use a magnet to hold the door in the up/closed position, and you just give the door a push down to open it when you land. Air pressure will close it when you take off.
Old 06-13-2018, 03:40 PM
krw5927 krw5927 is offline
Andy, are you using 100LL? Its vapor pressure is lower than most (all?) mogas blends, especially if you happen to get some winter blend mogas at the pump and use it on a hot day.
Disregard if you're already using 100% 100LL.
Kurt W.
RV9A
FLYING!!!
Old 06-14-2018, 01:21 AM
Not 100% 100LL, but I keep 1 tank strictly 100LL for takeoff and landing. I use 91 ethanol free mogas in the other tank at lower/cooler power settings mostly in cruise. I switch to my 100LL tank with my BCGumps landing checklist, I might not have burned all the mogas out of the system as Iím taxiing in. Iím not convinced itís a mogas Problem, but easy to eliminate the possibility with 100% 100LL usage.
12/17 donation
Old 06-14-2018, 01:27 AM
Mikey,
Iím carbureted with dual electronic ignition and auto plugs, I think the fuel is boiling in my carb bowl....
12/17 donation
