rv969wf said:Make sure you don't have any burrs on the crank prop hub/ flange. Something that I do is tape the crank flange with several wraps of 2" vinyl tape to make sure that the seal does not get cut on the crank flange and I use a brass rod that is polished with NO burrs and well oiled to install the seal over the hub. The seal will stretch better at high temps 90F+ days. I wouldn't install one on a cold day. After getting the seal "ONE PIECE type Seal over the crank flange I clean the O.D. of the seal with alcohol and let it relax to shape and size, then apply "PLIOBOND" contact cement to the case bore and O.D. of the seal and push it into place and then allow to dry overnight. Do not get any of the contact cement on the seal area and make sure there is a light film of oil on the seal surface and the crank. Something else that I have added is a split ring that bolts to the front of the case like on the Continentals to prevent the seal from blowing out if your crankcase breather freezes over for some reason. I've had good luck doing it this way and I've had more problems with the prop hub slinging grease out (Constant Speed) than the crank seal.
Low Pass said:Very interesting! I'm in that very same boat with my 160-hp CS prop -320. Been through 5-6 seals in 7 yrs and 875 hrs, including 1 custom dual seal (current). Next mod will include applying a vacuum between the seals.
I had figured it was most likely my poor prep job on the crank seal area. But I also suspected the governor.
Any thoughts on altering any governor settings? Other ideas? I really am tired of the oily mess.
LifeofReiley said:Can you share a pic of your split ring setup? Sounds interesting! We've installed crank seals in the same manner you decribe for years with no leaks or problems.
smokyray said:Hi Chuck,
The original 0-320A in my Bandit had crank seal leaks. After extended aerobatics it would pop out after which I finally decided to replace the seal. During the re-installation my Dad (a long time engine builder) taught me a few tricks on installing the new seal. First, prep the crank flange by rubbing it down with sandpaper getting all the burrs and tape it as pictured above. Next you immerse the seal for about 3 minutes in boiling water. There is a special tool for stretching the seal around the flange. Permatex works great to hold the seal in, and I also added a crank seal hold-back plate to keep it from popping out. One thing to add, my airboat lycoming builder friend uses after market crank seals that work better. My new Airboat Super 0-320 in The Bandit has no leak issues whatsoever. I will try to find out where they come from...
Rob Ray
RV4
1500+ hours and counting
Low Pass said:Here's my situation. 160-hp, O-320 with CS prop. I just installed crank oil seal no 8 (guessing). Engine's got ~915 hrs over 8 years. Has had a leaky crank seal essentially from day 1.
I've had people tell me that I needed to ground the plane and overhaul the engine immediately. BS! It's got great compression (topped 150 hrs ago) and is very powerful & smooth - but leaky.
There's something - probably to do with the crank seal surface prep + the high pressure oil from the CS prop - causing the problem. BTW - the sealing sfc under a lip seal needs to be as smooth as possible to work effectively. Mine's marginal.
Regardless, I am continuing to think about alternate seal configurations.
I just removed a dual (back-to-back) seal. Made with two seals and a gland to contain the outer seal. Had the space between the seals piped overboard. It finally gave way to the point requiring replacement last week.
I have two new ideas. These are:
1. Install a vacuum pump and draw a vacuum on the crankcase in order to reduce the tendency to push oil out the front seal.
2. Install a vacuum pump and pull a vacuum on the space between the dual seals.
Thoughts about the vacuum ideas?
Thanks for the help, but have seen this. I'm just trying to put off the inevitable of splitting the case as long as possible.gasman said:Read this....... http://www.sacskyranch.com/eng64.htm
