Old 05-05-2018, 08:12 PM
vernon smith's Avatar
vernon smith vernon smith is offline
Default Blown "2 amp start fuse"
We did some checking and found the Rotax solenoid has 4.2 ohms resistance. then put an amp meter in the fuse position and get 2.2 amps draw during cranking. These numbers jive pretty well with Mr. Ohms law so the question is, should the start fuse be larger or am I developing a bad solenoid?
We could not find any specification for the Rotax solenoid but all the other solenoid specifications we were able to find would draw more amps than the Rotax.
Old 05-05-2018, 08:25 PM
DHeal DHeal is offline
I believe that Van's approved a 3 amp fuse for the starter circuit several years ago -- check with Van's techs. My circa 2013 RV-12 plans depict a 3 amp starter fuse. I have had no problems with this 3 amp fuse.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 725+ hours (as of Jan 2019)!
VAF donation through June 2019.
Old 05-05-2018, 08:27 PM
skydiverlv skydiverlv is offline
http://www.vansairforce.com/communit...ght=start+fuse
Larry Vandegrift
ULPower 260is
