Old 04-02-2018, 12:18 PM
bkervaski's Avatar
Default Drilling pushrod woes ..
I'm down to installing pushrods into my wings and then I get to close them up, take them to the hangar, and final assembly!
This weekend, drilling pushrods and subsequently getting a rivet in them straight proved to be quite a challenge.
Here is a pic of my .. ahem .. practice piece. I can't keep the bits from roaming from one side to the other. I've tried short and tall bits and have tried scoring the location with a punch, etc. No luck, every other attempt to drill wonders off to one side or the other.
There has to be a better way to drill these things .. hoping I'm missing something simple.
I have the press set to its lowest rpm.
Any advice appreciated!
Progress: Flying!
Old 04-02-2018, 12:22 PM
TShort TShort is offline
One thing I have found is to use a bit that is as short as possible, and insert it fully into the chuck ... that looks like a 12” bit, and those things will wander all over, especially in #30 and #40...
Thomas Short
KUMP - Indianapolis, IN
RV-10 N316JS bought / flying
RV-8 wings / fuse in progress ... still
N329TS (had it, lost it, looking for new number)
Here you go:
https://www.google.com/search?ei=kGb....0.CceTZJ1i2T0
You can get a usable set from Harbor Freight; fine for drilling aluminum.
edit:
https://www.harborfreight.com/center...-pc-60381.html
Center punch, then use the smallest bit from the above set to start the hole. Finish with the correct numbered bit.
Old 04-02-2018, 12:25 PM
bkervaski's Avatar
One thing I have found is to use a bit that is as short as possible, and insert it fully into the chuck ... that looks like a 12 bit, and those things will wander all over, especially in #30 and #40...
Yep, I tried the short bits too.
These rods are steel .. but I don't mind tearing a couple bits up if I can get them drilled properly.
Progress: Flying!
Old 04-02-2018, 12:29 PM
Mark Dickens's Avatar
I just take my hand drill and very carefully drill a #40 pilot hole on one side. Then put it in the jig and drill it through to the other side with the drill press. It's always worked for me.
RV-8 #81077 Super Slow Build
Titan IOX-370, Dual P-Mags, AFP FM200A FI, Sensenich GA Prop
First Flight 11/20/2016
www.marksrv8.com
Old 04-02-2018, 12:50 PM
I've used mine on steel quite a few times without noticeable issues. Don't expect them to last like hi-$ stuff, but you're not going to use something like this for production work.
Old 04-02-2018, 01:04 PM
wirejock's Avatar
wirejock wirejock is offline
Default V-block
I center punch. Then use a tiny bit like #50 to drill a hole and move up incrementally. Tiny bit is less likely to wander from a punch mark. A V-block helps but not necessary.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 04-02-2018, 01:05 PM
Bavafa Bavafa is offline
Plus 1 for this method. All you need is a small pilot hole and light pressure on your drill press, throttle the arm of your drill press.
If this is the aileron push rod, the more challenging part is the riveting part. Go really slow with the rivet squeezer or better yet use your vice on the table (if you have one) to get the rivet set and then the rivet squeezer to finish it.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Phase one
Dues paid
Old 04-02-2018, 01:07 PM
scard's Avatar
scard scard is offline
Spot drill
Scott Card
CQ Headset by Card Machine Works
RV-9A N4822C flying 1900+hrs. / Cedar Park, TX
Old 04-02-2018, 01:10 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
You could try this
http://www.aircraftspruce.com/catalo.../drillrite.php
although I seem to recall that the advice here, all taken together, was all I needed...short bit fully stuffed up into the arbor, start small, go VERY slowly, and make sure your workpiece is firmly clamped so it doesn't move. It's key to get the desired location dead nuts under the bit *and* at the very top of the tube...any off-to-the-side positioning will start the bit wandering.
2019 Dues paid!
