Old 03-21-2018, 10:17 AM
dave4754's Avatar
dave4754 dave4754 is offline
Unhappy Prop bushings
I have purchased a Sensenich metal prop requiring 7/16 bushings in the flange.
My Lycoming O-320-B2C has 3/8 bushings in the flange.
Can anyone help me with the part number needed to order the new bushings?
As usual at ACS no one knows their products and are NO help in determining the required part. is there anyone else to order from, after thousands spent there the frustration of trying to get order help is too much!
For those quick to point out the archives here please point away as I have Searched and have had "nojoy" so far.
Thanks for any and all help.
Dave Cobb
=VAF=2018 Donation - and a bit extra for great work!
Empennage RV 7 - Tipper
Wings complete
Fuse nearing completion, Canopy complete
AME reviewed and repaired O-320-Lyc installed
Old 03-21-2018, 10:33 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
To get you started a search of Prop Bushings came up with this VAF thread of Changing Prop Lugs O-320. Good info as always with Lycoming SI reference in post #6.
Update: Here is the LINK to the most current SI 1098N pdf dated 2.14.2018.
Carlos in Arizona
EAA Chapter 538 President, www.538.eaachapter.org
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 03-21-2018, 11:51 AM
MS19087's Avatar
MS19087 MS19087 is offline
Default Call Saber!
They can set you up with the correct set very quickly. The swap out is very easy . . .
http://www.sabermfg.com/bolts.htm
RV-9A; IO-320 w/ Whirlwind WW-151
(Flying since June 2011)
RV-14A; tailkit
2019 =VAF= donor
Old 03-21-2018, 12:05 PM
Can you not achieve the same thing in your prop spacer? I know you can with the old 4" spacers; I've run multiple different 3/8 & 7/16 sized props on my 3/8 lug O-320.
Old 03-21-2018, 12:24 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
If you want to change bushings be sure to call your local engine rebuilding shop.
Whenever they scrap crankshafts they usually remove all of the prop bushings and will have a bucket full to sell cheap.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-21-2018, 01:00 PM
JKevin JKevin is offline
Default RE: Prop lugs
I have a set available that I purchased to change an O-320 but never used. Measure your flange thickness and PM or e-mail me if interested. littlemiranda at gmail
Kevin
Kevin
RV-6 21390
N436KH reserved
Old 03-21-2018, 06:25 PM
cajunwings cajunwings is offline
Default Crank Bushings
Bob Merril at Aircraft Specialty Services in Tulsa can fix you up. They stock new and used serviceable parts. He will know what you need.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
Old 03-21-2018, 11:53 PM
dave4754's Avatar
Default wow finally some help
Thanks guys I will follow up on all the suggestions given.
Thanks again
Dave Cobb
Wings complete
