Old 03-20-2018, 12:45 PM
SgtZim SgtZim is offline
Default Describe a normal takeoff and landing :)
Hi all,
Could anyone do a quick verbal brief on what a normal takeoff and landing are like in an 8?
I just finished a fresh tailwheel endorsement in an Aeronca Champ - 90% on a grass runway, and am looking for transition training this summer before I finish construction. I did some flying of a Citabria many years ago off of hard surface and I'm sure that was a bit closer to RV performance.
Thanks!
I'm located near Cincinnati if you know of a good instructor in the area.
RV-8 slow build
IO360-M1B Sensenich fixed pitch
Garmin G3X
GTN 625
GNC 255
GTR 20
GTX 45R
G5 x 2
Facebook "log" https://www.facebook.com/BZsRVproject/
Old 03-20-2018, 01:06 PM
mike newall's Avatar
Compared to a Champ......
https://www.youtube.com/watch?v=G6XofY0dysc
Donated in 2018
Old 03-20-2018, 01:58 PM
Mark Dickens's Avatar
I have no experience in a Champ, but I think it's safe to say that transition training in an RV would be strongly suggested, especially on hard surface runways. Takeoff isn't the issue, but it does happen fast and because of the horsepower, there can be noticeable P factor and left turning tendencies. An -8 will get up and go and you need to be ready for it. Landings of course are a challenge. Read http://www.vansairforce.com/communit...ad.php?t=16788 for more info. Suffice it to say that the stiff legs on the RV-8 will bounce you back into the air with the slightest error. Three point landings can be made, but they are difficult and you have to have your airspeed control and timing just right. This is why most wheel land their -8s. I wouldn't assume that Champ training makes you ready for an -8 or anything other RV, and I'd strongly suggest transition training.
RV-8 #81077 Super Slow Build
Titan IOX-370, Dual P-Mags, AFP FM200A FI, Sensenich GA Prop
First Flight 11/20/2016
www.marksrv8.com
Old 03-20-2018, 05:27 PM
Ron RV8's Avatar
Ron RV8 Ron RV8 is offline
I have flown both and second Mark's comments above..
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Nov 25, 2018
Old 03-20-2018, 05:55 PM
rzbill's Avatar
rzbill rzbill is offline
Originally Posted by mike newall View Post
Perfect.
I actually have never experienced an RV takeoff since I shut my eyes tight and then firewall it.
Bill Pendergrass
ME/AE '82
RV-7A: Flying since April 15, 2012. 750hrs
YIO-360-M1B, mags, CS, GRT EX and WS H1s & A/P, Navworx
Unpainted, polished....kinda'
My RV Construction Page
Old 03-20-2018, 09:46 PM
Rallylancer122 Rallylancer122 is offline
Like others said, takeoff happens fast. It's kind of hard to screw up, just watch the torque. Although I guess anything is possible, I can't imagine departure stalling one of these.
Landing happens fast too. Your pattern speeds will be higher than Champ cruise speeds. You'll need to plan ahead to slow down and fly a larger pattern. Ours has a constant speed and on landing it can develop a pretty high sink rate so plan on carrying some power. With the Hershey bar wing it does not float. I chop the power, flare, and am on the ground about that fast.
Ours 3 points nice onto grass with a little weight on the back. Without weight it will not 3 point. I've never tried a stall landing on pavement. It wheel lands nice on either surface. Make sure the brakes and tailwheel steering are up to snuff because once the tail comes down the rudder is pretty ineffective. (I learned this hard way.)
Solo with 20-30 lbs in the back ours is a pooch to fly. With a full size adult back there it's a whole other animal. Not harder, just different.
Definitely get some dual.
DEM
Old 03-21-2018, 03:40 AM
YvesCH YvesCH is offline
Hi,
I fly currently a Champ with 100hp and I am building a RV-8 in Switzerland. As I had to go on a business trip to the US, I took the opportunity to visit Bruce Bohannon in Texas to get some RV-8 Stick time.. I will write about this trip maybe in another section but to summarize:
Yes the Video explains quite well the difference I even forgot sometimes to apply full throttle at takeoff as the acceleration was so intense
The RV-Grin is still on my face and the training was very very valuable!
Yves - Basel, Switzerland
RV-8 QB #83458 in Progress
Aerosport IO-360, Catto 3 blade, G3X Touch
HB-YUA reserved
Donation 2019 done
Old 03-21-2018, 06:03 AM
Capt Capt is offline
I owned a 7ECA for a few years and now have a conventional u/c 8, the primary difference is the speed and acceleration, they are just numbers, no need to be afraid just be aware��
I've got instructor friends who have many 1000's of hrs teaching but mention an RV8 & they start sweating! Too many people have old wives tales to frighten those that have not had the thrill of power up & rotate, there's no need to look at the speedo, Vans just want to fly, enjoy the ride��
Old 03-21-2018, 08:26 AM
BillL BillL is offline
I found a 100 hp Champ to be a good trainer for the RV7. Maybe just me, but I was more comfortable in the RV after getting my tailwheel endorsement in the Champ. If you can nail the approach speeds, rotate and land with little bounce in the Champ, then you won't have any problem moving to the RV, if your experience is like mine. Yes, it is way faster, and more P factor, but nailing the landing speeds and getting the vertical speed right at touchdown was extremely helpful in the Champ. Not at all to say transition training is not needed, but your first hours in the RV should come much easier with the Champ skills. At least if you are a low time TW pilot to start with.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Old 03-21-2018, 08:54 AM
Thanks for all your comments! Thanks Mark for the link! How did I miss that page!?
One of the strange things to me about the Champ takeoff (grass) was holding the stick full forward for several seconds until the tail came up - mentally a challenge / counterintuitive to try forcing the nose down during takeoff From that, I was imagining starting takeoff with stick full aft in the 8 for a couple of "bananas" for directional control until the rudder works, then lifting the tail. Sounds like the bananas slip by pretty fast.
Landings were almost all full stall in the Champ, wheel landings were tricky and discouraged by the management and instructors.
Really looking forward to some training in the 8 and flying!
RV-8 slow build
Garmin G3X
GTN 625
GNC 255
GTR 20
GTX 45R
G5 x 2
