Old 02-25-2018, 08:42 AM
bob888 bob888 is offline
Default Wing Walk Material
What is the best material for the non-skid wing walk area that goes on the upper wing root areas? What about the clear protective strip that protects the paint on the forward flap area? Thanks...
Old 02-25-2018, 08:46 AM
mike newall's Avatar
Ray Allen does it with a nice cut logo.
Spruce
Donated in 2018
Old 02-25-2018, 08:55 AM
Kyle Boatright Kyle Boatright is online now
Spruce
I have some of what I believe is the Ray Allen material on my -6. It has always been pretty slick when wet. I was hoping to find something with more grip for the -10.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 02-25-2018, 09:00 AM
Vans has some for the 10, nice cutouts for the gap cover screws too.
http://www.vansaircraft.com/cgi-bin/...uct=wing-walks
Old 02-25-2018, 09:40 AM
Mark Dickens's Avatar
I remember that some have used skate board grip tape as a wing walk material. I will be taking my -8 to paint in about a month and am thinking about what I'm going to use after that. Wondering if anyone had a pirep on using skate board material?
Edit: and it's a lot cheaper too
RV-8 #81077 Super Slow Build
Titan IOX-370, Dual P-Mags, AFP FM200A FI, Sensenich GA Prop
First Flight 11/20/2016
www.marksrv8.com
Old 02-25-2018, 09:43 AM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
3M makes a nice material that you can get from McMaster Carr
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
2019 donation current
Old 02-25-2018, 09:46 AM
Carl Froehlich's Avatar
Consider not putting it on the wing root cover. Just on the wing is more than enough, and that way you donít promote people kicking toes into the side of the fusleage. Just tell them ďif it is not black, donít step on itĒ. This seems to work.
Old 02-25-2018, 10:30 AM
kdedmunds kdedmunds is offline
Default Skate board material
If you want something that is completely custom, Google skateboard custom grip tape. The possibilities become endless. Requires more decisions
K Edmunds
Old 02-25-2018, 11:21 AM
9GT's Avatar
9GT 9GT is offline
Stay away from the clear stuff. It is easily soiled/stained and is near impossible to clean afterwards.
David C.
Howell, MI
RV-9A: Under Construction.
RV-10: Completed 12/29/2013 SOLD 08/23/2016
"Donor Exempt" but donated through Dec. 2019
Old 02-25-2018, 02:12 PM
JohnInReno's Avatar
JohnInReno JohnInReno is offline
Default Stair tape
I installed the usual rubbery wing walk material but it disintegrated in flight. I believe that my paint was too "slippery" and allowed the material to separate. If I used that again, I would prep the paint with 400 grit first.
At the time, I needed to replace one side while I was away from home so I used 3 lines of 2" Stair tape (3m?) from Home Depot or Lowes. It is rough on knees but sticking is terrific and there are no issues when it is wet. When I got home, I used the stair tape on the other side so it would match.
John Morgensen
RV-9A N946PM 600+ hours since 2013
Nevada/Arizona
