Old 02-12-2018, 03:08 PM
rvanstory's Avatar
rvanstory rvanstory is online now
Default Fuse Floor Pans
In process of putting in front floor pans on RV10. All is going well EXCEPT, the holes that are to be riveted to the lower fuse channels are WAY off! Match drilling all went well, but now, they aren't even close. I can't force it over enough to even get close.
Has anyone else experienced this? Any suggestions?
https://lh3.googleusercontent.com/22...U=w587-h780-no
Randy Vanstory
Building RV10
N783V - Reserved
Flying Mooney M20J
Emp Kit Completed, Tail Cone Attached, QB Wings delivered and starting Fiberglass Top.
Dues Happily Paid 2019
Old 02-12-2018, 06:06 PM
9GT's Avatar
9GT 9GT is offline
I had several metal scribes and awls to help in getting rivet holes aligned. Start at the holes most closely aligned and pull them together working your way down the rivet line. I had a few areas like you have here that had me thinking I did something wrong, but it all came together lined up using the awls and scribes.
https://www.amazon.com/Gourd-Leather...&keywords=awls
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2019
Old 02-12-2018, 08:35 PM
leok leok is offline
+1 for Dave
I was trying to remember how I did that row of rivets. I think it is the outside skin bend tends to pull that area out if it is a little under bent.
I had the same problem and solved it the same way. I used two and walked them along the row pulling things in line and adding clecos. HF has a nice set for about $5 I use all of the time to line things up for riveting, fish wires thru holes etc..
Building my RV-10 since Oct 5th 2014
Flying .. once I figure out how to pay for everything
http://www.mykitlog.com/leok
RV Hotel
Dues paid 2018
Old 02-12-2018, 09:06 PM
rvanstory's Avatar
Thank you David! That did the trick! Couldn't believe it looked that far off. I appreciate the help on this one!
Randy Vanstory
Building RV10
N783V - Reserved
Flying Mooney M20J
Old 02-13-2018, 05:43 AM
flion's Avatar
flion flion is offline
It's not that it's underbent but the weight of the structure itself causes it to sag and spread there. Taking the weight off by lifting at the top of the side skins helps and pushing in from the outside will get you the rest of the way. The awls are great for precise alignment. Once the pans are riveted, this area is rock solid.
Patrick Kelley - Flagstaff, AZ
RV-6A N156PK - Flying too much to paint
RV-10 14MX(reserved) - Fuselage on gear
http://www.mykitlog.com/flion/
EAA Technical Counselor #5357
Old 02-13-2018, 08:15 PM
bruceh's Avatar
bruceh bruceh is offline
Similar story on the RV-9 fuselage. Just a bit too much sag between the saw horses made it difficult to line up the various floor and side pieces. I took out the sag and everything got much easier to line up again.
Bruce Hill
RV-9A N5771H flown over 600 hours!
2018 VAF donator
EAA Tech Counselor
