Old 02-03-2018, 03:19 PM
Douglas Douglas is offline
Default RV 8 wings donít fit- what to do?
Attempted to stab the wings on my RV-8 with help of 4 highly experienced builders today. We could not get a fit and using electric calipers we discovered the wing is .08 of a inch wider than the slot it should go into. Other than calling Vanís on Monday has anyone else had this problem or know the fix?
Old 02-03-2018, 03:37 PM
Don Patrick's Avatar
Don Patrick Don Patrick is offline
Default Clarification.
Just want to clarify, the wing spars wont fit in the wing spar box?
What did you use for the spacer when you riveted that section together?
Quickbuild or slow build?
I would think that if you are out that much, you need to disassemble the spar box, space it properly and re-rivet. I used a CNC machined spacer I had fabricated and my spars went in with no difficulties.
I know others have used washers. I would think anything compressible like wood may cause your current issue.
Good luck. Call Vanís for their opinion. I would think that any adjustment to the spars would be a no no.
Don
RV-8 build
DONE!
C-GLOV
http://www.mykitlog.com/Don%20Patrick
2018 donation contributor.
Old 02-03-2018, 04:15 PM
terrye terrye is offline
A friend had this happen on his RV-9A. The plans are not very clear about using a spacer (I think they say wood) while riveting the bottom front skin to the skin aft of the spar. In his case, he de-riveted this joint, spread the front and rear fuselage spar halves apart and re-riveted. Seemed to work OK and even used the same dimpled rivet holes.
In my case I made hard plastic delrin spacers just wider than the measured wing spar prior to riveting, although I have not yet tried to fit the wings.
Terry Edwards
RV-9A (Fuselage)
2018/2019 VAF Contribution Sent
Old 02-03-2018, 04:38 PM
9GT's Avatar
9GT 9GT is offline
I used a spreader. A bolt with a nut and washers on both sides. Lots of ways to do it, just make sure you can get it out, and it won't leave a scratch. I put the bolt through the main spar holes, one upper and one lower. It did not take much to move it a few thousands. I did a dry run on each side. Have a magnet on a stick handy.
Easier if there is a block and the bolt can be turned and just hold the nut. I may have a picture.
He's .080" short, that's more than a 1/16 of an inch. Somethings going to give trying to spread it that much and it won't be pretty.
David C.
Howell, MI
RV-9A: Under Construction.
RV-10: Completed 12/29/2013 SOLD 08/23/2016
"Donor Exempt" but donated through Dec. 2019
Old 02-03-2018, 04:53 PM
The wings were a slow build kit and the fuselage was a quick build. Both are recent kits.
Old 02-03-2018, 05:07 PM
Slow build wings and quick build fuselage.
Old 02-03-2018, 06:51 PM
wirejock's Avatar
wirejock wirejock is offline
Default Vans
Worth a call to Vans so they know there's a QB problem. Most likely they will tell you as others said to drill the rivets on the center section, bolt in spacers and rivet back together.
I used Buller spacers but mine was a SB. Spacers were .005" thicker than the wing soars. Wings go in with a little coaxing.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 02-03-2018, 07:36 PM
BillSchlatterer BillSchlatterer is offline
Default What's the dimension ?
Just curious if anyone has the exact width dimension on the upper and lower wing spars where the bolts go through?
Doug's issue is a puzzle? The fuse is a quick build so the spar box should have been assembled at Vans with the correct spacers .... shouldn't it?
Every spar I have stabbed so far (4) has pretty much slid right in once you were holding your mouth right
Bill
Bill S
Got the Grin :-)
7a Ark KORK
BillSchlatterer@sbcglobal.net
Dues Paid for 2019
Old 02-03-2018, 07:55 PM
wirejock's Avatar
Default Measurement
Bill
Yes. That's why I suggested a call. Clearly they missed because spars are supposed to be so precise they are no longer a matched set with the center section. I have even seen fuses built without spacers and the wings fit.
He did say they were experienced builder helpers so one would assume they know how to get the wing spar to slide in.
My soars were 1.439". My spacers were 1.444". It's a 7.
Larry Larson
Estes Park, CO
Disclaimer
Old 02-03-2018, 09:43 PM
longranger's Avatar
longranger longranger is offline
I used wood spacers from another builder, and my slots came out 10-15 mils narrower than the spars (slow build -7). However, there is enough flex in the structure that by slightly chamfering the ends of spars and greasing the spars and the slots per instructions, the wings went in with surprisingly little effort. I I ever do it again Iíll have some steel or aluminum spacers fabricated.
I would guess that 80 mils would be a different story; thatís about 85% of the diameter of a #3 rivet. I would be a bit torqued if Iíd paid extra for a QB fuselage and got something like that. Drilling out that center section wouldnít exactly be a trivial task...
Miles (VAF# 1238, Paid up as of 2018)
RV-7 TU 904KM (reserved)
Wings Fitted and Finish Kit on site
Construction Log
Picasa: Empennage Album, Wings Album, Fuselage Album
1955 Cessna 170B flying since 1982
'To get something you never had, you have to do something you never did.' -Unk.
