Old 01-29-2018, 08:42 PM
Cwood2000 Cwood2000 is offline
Default Roteseri
Anyone have any plans or designs for one?
Aka YellaDawg
RV4
RV14 in gestation
Old 01-30-2018, 05:22 AM
M McGraw's Avatar
M McGraw M McGraw is offline
Default Pictures
I bought two Harbor Freight engine stands, about $35 each. Removed the third leg and ran a board between them to keep them from splaying out. Used the engine mount holes on the firewall. Built a plywood box around the wing spar. The wingtip and the fuselage tail are sandwiched with plywood.
Note: The third picture is temporary, the board has not been added.
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 250+
2019 Dues Paid
The Dues Paid note is a reminder for me
Old 01-30-2018, 07:14 AM
Jared_Solomon's Avatar
Jared_Solomon Jared_Solomon is offline
Default Rotisserie
I also bought the harbor freight engine stand. Worked great. You can see pictures and details at the link below:
http://rv14.jaredsolomon.net/post/ot...ge-Rotisserie/
Jared Solomon
A&P, EAA Technical Counselor
Powder Springs, GA
2019 Dues Paid
RV-14A (N214WJ) - Flying since Sept 2017
RV-7A (N211WJ) Flying since 2009 (SOLD)
RV-7A (N132RD) bought flying 2014 (SOLD)
KPUJ (Silver Comet Field)
Youtube channel: http://www.youtube.com/jmsolomon2000
RV-14 Build Log: http://rv14.jaredsolomon.net
Old 01-30-2018, 07:16 AM
asw20c asw20c is offline
How did you determine where the axis of rotation relative to the firewall and aft bulkhead should be?
Empennage Complete Except for Tips
Wings Underway
Old 01-30-2018, 07:40 AM
I lined up the bottom of the engine stand plate with the bottom of the firewall. So the access of rotation would mimic rolling the fuselage on flat table. I then laid the aft end of the fuselage on an adjustable height sawhorse I bought from Lowe's. Whenever I rotated the fuselage the aft end would just roll a few inches on the sawhorse.
You can see the sawhorse at the aft end of the fuselage in the pic below
Jared Solomon
Powder Springs, GA
2019 Dues Paid
Old 01-30-2018, 08:41 AM
Sam Buchanan's Avatar
been here awhile
No need to overthink this....
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 01-30-2018, 09:30 AM
Really? Seems to me if you rigidly attach an engine stand with a single degree of freedom (roll) at both ends of the aircraft and the axis of rotation does not accurately align and go through both, then you run the risk of tweaking/bending the fuselage. If you only attach an engine stand at one end, presumably at the firewall, and simply let the aft end rotate on an adjustable height table or saw horse, then I would agree with you that there isn't much thought that needs to go into how to align the rotation axis.
Although now that I think about it some more, you can have a single degree of freedom on one end, but you will need 3 degrees of freedom on the aft end, hence the offset attachment from the OP's photos.
Wings Underway
Old 01-30-2018, 09:34 AM
Default How long on stand
For those who have gone before..... how long does the fuse need to be on the rotiserrie ?
John S
Dues paid 2019, worth every penny
Fuselage 30%
Old 01-30-2018, 09:35 AM
wirejock's Avatar
wirejock wirejock is offline
If you don't feel like building one, but one of these. I have one and it's awesome.
http://www.vansairforce.com/communit...ght=Rotisserie
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 01-30-2018, 09:37 AM
Default Agreed
That's why is left the back of the fuselage on a saw horse
Jared Solomon
Powder Springs, GA
2019 Dues Paid
