Old 01-03-2018, 03:15 PM
strahler13's Avatar
strahler13 strahler13 is offline
Default FS Sensenich Composit Prop
Only 250 hours since new. 70" diameter. A couple of small scratches on one blade (see photos).
New price $1,760
Asking $995
Also have 12" carbon fiber spinner and back plate. New $558. Asking $250.
Mark Strahler
RV-6 (Purchased flying)
KFFC-Peachtree City, GA
Old 01-03-2018, 03:28 PM
moosepileit moosepileit is offline
What spinner, bolts, crushplate (if any?) and extension to goto this from a Sens metal 70CM6?
Exempt, but 2016 dues gladly paid!
RV-6 N91GG, bought from builder.
O-320, slider
Old 01-03-2018, 03:54 PM
Sensenich makes composite props for all kinds of stuff, from airboats to light sport to Lyc 320/360. It would help you sell it if you included actual model numbers.
Old 01-03-2018, 04:34 PM
kg6kct kg6kct is offline
Default Sensinich prop
I sent you a PM
Old 01-03-2018, 04:41 PM
YellowJacket RV9 YellowJacket RV9 is offline
It appears to be this model: http://www.aircraftspruce.com/catalo...clickkey=10416
which is designed for LSA (rotax, jabiru, etc). I'd jump at a GA prop for my 9A at that price, however - hope I'm not missing out...
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 01-03-2018, 04:55 PM
DonFromTX's Avatar
I own two Sensenich Rotax hub props, this hub is not a Rotax I don't think.
AF1 (was RV12) EAB Air Force One, SN 461, N461DG VIKING/HONDA ENGINE POWERED! AND N756TS ROTAX POWERED
Retired US Army Officer
http://www.mykitlog.com/users/index....X&project=1903
Old 01-03-2018, 05:25 PM
strahler13's Avatar
Hub code is 22735. Blades are S20/690. Came off Rotax 912ULS. Can post more pictures later.
Mark Strahler
Old 01-04-2018, 08:18 AM
strahler13's Avatar
Default More Pictures
Mark Strahler
Old 01-04-2018, 08:48 AM
DanH's Avatar
DanH DanH is offline
Mark, I need a prop for an 80 horse 912 on a Kitfox. Checking numbers.
I think you're posting serial numbers. Likely model numbers would be:
2A1R5R64DN
2A0R5R64EN
2A0R5L69EN
2A1R5R70DN
2A0R5R70EN
2A1R5R75DN
3B0R5R68C
POSTSCRIPT: Sorry won't work for me. Probably wrong bolt pattern; my 912 hub is an early 75mm.
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-04-2018, 10:05 AM
strahler13's Avatar
Dan, this is the prop.
http://www.sensenich.com/products/item/44
http://www.sensenich.com/files/docum...1314811785.pdf
Mark Strahler
