Old 01-03-2018, 12:40 PM
goanddo goanddo is offline
Default Proud Screw in transponder tray
This is a picture of the remote transponder tray for the Garmin GTX 35R/45R. The problem is the the screw I ordered, a (ms224694-s50) 10-32 flat head screw sticks up proud inside the tray. The tray came with the hole counter sunk. Should I have ordered a different screw? Has anybody else had this problem.
Thank you.
Old 01-03-2018, 12:48 PM
bkervaski's Avatar
I ordered a bunch of random sizes from aircraft spruce just for the avionics .. I don't recall which ones I used but they fit well. Try #8 .. not many options, you can't really adjust that hole.
Edit: Also test fit the unit once you go down a size, even if it's slightly proud the unit may not touch the screws, I remember this being the case with mine.
Progress: Final Assembly
Old 01-03-2018, 12:52 PM
bkervaski's Avatar
Here's my brackets; $10.00 for experimental version, $2499.99 for certified:
Old 01-03-2018, 01:06 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
A #10 screw is too big. I think I used #8 screws.
The installation manual will have the proper hardware callouts in any event.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
n82rb's Avatar
n82rb n82rb is offline
I don't know what the garmin manual calls out but a number 10 sounds rather big for a avionics tray.
Bob burns
Old 01-03-2018, 03:16 PM
wjb's Avatar
wjb wjb is offline
I used a #6 flat head, I believe (6 places); the head on the #8 seemed a bit proud, too...
Bill Bencze
N430WB (reserved) RV-7 #74152, tip-up. Avionics and FF underway!
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2018 donation happily made
Old 01-03-2018, 03:19 PM
9GT's Avatar
9GT 9GT is offline
I used a #8 or #6 IIRC.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2018
Old 01-03-2018, 03:38 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
No wonder you had trouble.
The Garmin typical installation guidance manual (I used the GTX345 one) calls out #6 hardware.
3 locations per side. Two at the front and one as a rear support.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
