Old 01-03-2018, 03:28 AM
bobnoffs bobnoffs is offline
Default max temp of proseal
i need to have aluminum welding done close to an inspection hole in a fuel tank. the inspection hole doubler and nutplates are sealed with flamemaster. a call to the mfgr. was an exercise in futility. i can't find any info in the msds sheet. i am wondering what the max temp is i can heat the area to without damaging my sealant. any info is appreciated.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying
RV-12 kit as of 9/13
Old 01-03-2018, 04:48 AM
Default What are you welding?
I'm not sure what your welding, but the RV tanks are made from 2024 (welding not recommended for 2XXX series aluminum)..but you can make a heatshield per say for the nutplate area with some water soaked rags or paste insulation. TIG/MIG welding doesn't create as much heat as torch welding. I have seen Proseal handle some pretty good heat, but do not have factual temperatures.
Bill E.
RV-4/N76WE
41 Aeronca 65TC Defender
8A7 / Advance NC
Old 01-03-2018, 06:17 AM
not a van's tank. my own design. 5052 aluminum, very weldable. the welds will be 4-5'' from proseal and not a continuous weld. spot 1/2'' skip a couple inches etc. i was thinking about a wet towel and my take on it is that will work but would like to see any opinions.
Bob Noffs
n. wi.
Old 01-03-2018, 09:31 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Here's a typical data sheet. Intermittent exposure to 275F max.
http://www.ppgaerospace.com/getmedia...40_class_b.pdf
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-03-2018, 11:04 AM
grubbat's Avatar
grubbat grubbat is offline
Default Proseal
I can not fathom a worse smell that the smell of burning proseal while attempting to weld a piece of alum. Itís kinda hard to describe. You will definitively remember it though.
Craig
RV-3 Sold
RV-6a Sold
RV-9 IO-360 CS, Flying
1946 Piper Cub - in process......
Old 01-03-2018, 11:56 AM
thanks gil, looks like i can make this work.
Bob Noffs
n. wi.
Old 01-03-2018, 01:44 PM
Ron B. Ron B. is offline
Can you have a wet cloth or something over the proseal area to keep that cool while welding?
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 01-03-2018, 02:50 PM
yep, with a working temp way above boiling i can keep it cool enough with a wet towel. welder says it probably won't even get too hot to touch in that area.
Bob Noffs
n. wi.
