Old 01-02-2018, 02:34 PM
MED MED is offline
Default Aileron Push Rod Boots?
A friend asked if I was installing boots where the push rods enter the fuselage at the wing root. Anybody doing this? Did you make your own?
MED
140236
N435MD reserved
Old 01-02-2018, 02:35 PM
Nova RV Nova RV is offline
I believe Abby at Flightline Interiors was working on some for the 14.
Chris Moon
Leesburg, VA
RV-14A kit # 140243
VAF 2017 and 2018 paid
www.mykitlog.com/chrismoon/
Old 01-02-2018, 03:05 PM
RVDan RVDan is offline
I did this on my -6A to reduce cold air. Got some lightweight rubberized fabric from local place and sewed up a pair and glued in place to the fuselage side wall. I tied the fabric through a slot sewn in the fabric around the control rod to cinch the fabric to the rod. Check and double check for clearances.
They can be bought from various sources, but most glider folks who have been using boots on the controls for years like myself make them at home.
Dan Morris
Frederick, MD
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 01-02-2018, 03:18 PM
akarmy's Avatar
akarmy akarmy is offline
On 2 planes now I'd installed them. I just take a set of Tyvek coveralls from the Home Depot paint department, cut the sleeves off just above the wrist and about 8 inches up the sleeve. Then zip tie it around the pushrod and make a small circle of aluminum the size of the sidewall opening and glue it with RTV / pop rivets in place to hold it to the sidewall.
Andy Karmy
Covington WA
RV-8 - Flying!
RV-9A - sold
Nov 2017 Paid
gnuse's Avatar
gnuse gnuse is offline
I got mine from Abby, and it made a dramatic difference in reducing cold air entry. Her's are very nicely made.
George
"God does not deduct from one's time on earth that which is spent in the air."
Old 01-02-2018, 03:34 PM
RV6_flyer's Avatar
I purchased a set from someone that is made out of nylon windbreaker material. Very light and works great.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 01-02-2018, 04:03 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Another material used by the glider guys is chamois leather, soft and flexible and glues well with contact cement.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-02-2018, 05:33 PM
scsmith scsmith is offline
I did just about the same thing.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 500 in 8-3/4 years
also LS-6-15/18 sailplane
VAF donation Dec 2017
Old 01-02-2018, 06:05 PM
vlittle's Avatar
vlittle vlittle is offline
Thrift store. Child's rain coat. Use the sleeves.
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 under construction
Old 01-02-2018, 06:08 PM
MED MED is offline
Thank you to everyone. This certainly gives me something else to think about.
MED
140236
N435MD reserved
