Old 01-02-2018, 01:16 PM
DonFromTX's Avatar
Default A Tale of Two Twelves
Something bugging me, I have flown a total of two RV12s, mine and the one Jetguy owns. In his it took a whole bunch of right rudder to keep on the centerline, with mine it does not require that. Same load, same engine, same plane, what would cause that?
Retired US Army Officer
Old 01-02-2018, 01:36 PM
Was it dragging a brake on the left side?
Old 01-02-2018, 01:39 PM
sf3543 sf3543 is offline
Cross wind on that big tail will do that
Steve Formhals
RV6, RV8 (2), RV12 & RV3 99% done.
A&P, Tech Counselor & Flight Advisor
Old 01-02-2018, 02:31 PM
I'm discovering (in a completely different aircraft type) that things like alignment of gear leg fairings can also make a large difference in how much rudder is required to keep the ball in the centre.
Old 01-02-2018, 04:25 PM
Manual trim tab on rudder?
Hinckley, Ohio
EAA #499867
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 406
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 01-02-2018, 05:09 PM
DonFromTX's Avatar
None of the suggested reasons apply, in fact with a crosswind I had to actually put in full right rudder AND some brake to keep centerline on takeoff. I think (but not positive) our props are pitched at each extreme limit, could that do it?
Old 01-02-2018, 05:14 PM
greghughespdx greghughespdx is offline
Would be interesting to compare the rudder shape/flatness/etc. of both airplanes.
Van's Aircraft - Director, Community/Media
Van's web site | Instagram | Facebook
Opinions, information and comments posted by me are my own unless stated otherwise. They do not represent direction/opinions of my employer.
Building RV-8A since Sept 2014 (N88VX reserved)
Dual AFS 5600, Avidyne IFD 440, Whirlwind 74RV, Superior XPIO-360
VAF build thread - Flickr photo album - Project Facebook page
Flying spam can, helped build/fly a few RV-12s and some other RVs
Hillsboro, OR (EAA 105)
Old 01-02-2018, 05:57 PM
DaleB's Avatar
DaleB DaleB is offline
How does it fly, and do you have a trim tab or wedge?
I've noticed that some days I need a boot-full of rudder and sometimes the occasional tap of the brake to keep it straight while taxiing; other days not so much. I attribute most of it to that big sail of a vertical stab.
I do know, however, that it was much worse trying to taxi when the nose wheel (sorry, nose fork) breakout force was way too high. Fixing that made a huge difference.
Dale
Omaha, NE
Previous RV-7 project (sold)
-=VAF=- 2017 dues paid
Old 01-02-2018, 09:11 PM
mike newall's Avatar
Check the torque on the nose bolt and make sure it is castering correctly. Maybe too much load and a lack of centring ?
Donated in 2018
Old 01-03-2018, 06:56 AM
BigJohn BigJohn is offline
Default Off Topic Question
Don, I was just thinking the other day I havent heard from you in a while, or maybe I just missed it. What is the status of your BFR and RV-12 checkout?
“Master Pilot” Award, UFO Member.
One Week Wonder Build Team, OSH 2018.
VAF paid through 10/2019.
