Old 01-01-2018, 10:37 PM
Graham Graham is offline
Default Cummins Spinners
Folks,
I am fitting a Cummins aluminium spun spinner to my almost completed RV6.
The Cummins installation instructions do not require the spinner to be checked for "tracking" of the nose as the Vans instructions do. This is presumably because there is no need to trim the aft edge of the Cummins spinners, whereas the Vans spinners need trimming.
Can those of you who have fitted these spinners please advise whether they bothered checking the tracking prior to drilling the spinner backplate & fwd plate.
Thank You
Graham
New Zealand.
Old 01-01-2018, 11:57 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Ours was dead on, without any need for adjustment.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-02-2018, 08:37 AM
Larco Larco is offline
Same here, dead on. We love our spinner! :-)
Old 01-02-2018, 09:33 AM
pilotkms pilotkms is offline
I mated the back edge of the spinner to the back edge of the backplate. In addition to appearing properly centered visually, I subsequently Had my prop dynamically balanced and the balancer advised it had no impact and he had to remove the VERY thin shim-weight that was installed on the prop by the factory to remove the SMALL amount of vibration.
Keith
RV 7A RV #9700
N325KS the Flying “K”
Built in SoCal KCCB, now @ KPXE
250+ Hours & 5x cross the USA
2018 OSH - yes
Old 05-29-2018, 01:49 PM
Hangar 1271 Hangar 1271 is offline
Default All those screws!
I am installing a Cummins spinner on my RV-8. The installation instructions call for 7 screws in the forward plate and 14 in the aft plate. Well, why does one need the 7 forward screws? Certified planes with aluminum spinners don't have them. Does anyone have experience and an informed opinion that might answer this question?
David
David
305h@mazergroup.net
Old 05-29-2018, 01:55 PM
Bavafa Bavafa is offline
I also like to know the measurement for the front screws. The instruction says 9-3/16" but my measurement doesn't put that right in the center of the front spinner. Also, I think there is 6 screw in the front and not 7. The instruction youtube video says 7 but if you follow it and mark it, you will come with 6 screw.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Phase one
Dues paid
Old 05-29-2018, 02:12 PM
You know, I just finished the drawing for the forward screws and hadn't even realized I drew 6 following their instructions but heard, and remembered, 7. Very good point.
I don't think the goal is to put the forward screws in the middle of the spinner but in the middle of the forward mounting plate.
David
305h@mazergroup.net
Old 05-29-2018, 03:09 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
David
My Tiger has 16 screws in the aft prop bulkhead and 6 in the forward prop bulkhead.
Early models only used screws in the aft bulkhead but were soon replaced by a Service Kit that has the screws and forward bulkhead described above.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-29-2018, 04:23 PM
This is what I mean, in the middle of forward mounting plate FLANGE.
Please let us know how your measurement jibs down with this.
Mehrdad
Dues paid
Old 05-29-2018, 07:52 PM
Default 30 degrees
I made my back plate mounting holes every 30 degrees. An easy measurement for 12 bolts. Good luck with 14 back plate screws.
Also makes 6 bolts for the front plate rather easy.
Yes, u want the holes to be in the center of the front plate flange. I followed the directions and they worked.
As to why - someone else with an engineering degree can calculate the force being exerted as that thing spins at 2700 rpm. I wouldn’t leave them out. I have seen some RVs without the front plate bolts but the builder did much more engineering and added substructure in their assembly that was way beyond me.
Keith
RV 7A RV #9700
2018 OSH - yes
