Old 01-01-2018, 05:56 PM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Default Maintenance Tracking Board
In another thread (which was in danger of being hijacked), I was asked by Plummit about my maintenance tracking board:
Questions, with answers:
Did you apply the divider lines? How?
Answer: I applied the divider lines using line tape from Office Depot.
Where did you get the board?
Answer: Office Depot.
Bonus info: The Event and Interval text is applied using permanent marker (although alcohol will wipe that text easily). The Last Completed and Text Due info is done in normal white-erase marker.
Scroll
Sid "Scroll" Mayeux, Col, USAF (ret)
52F Aero Valley Airport, Roanoke TX (home of DR's Van Cave)
"KELLI GIRL" N260KM RV-7A tipper, YIO-360M1B with Danny King “Beautiful Doll’s” old Hartzell CS prop, dual PMAGs, dual SkyView, GTN-650, VPX, EarthX LiFePo4.
Nose Art by VictoryGirl.com. Smoke by Smoke System Helper.
90% done, 90% to go...
www.mykitlog.com/scrollf4/
Proud and grateful 2019 -=VAF=- Contributor
Old 01-01-2018, 06:16 PM
blueflyer's Avatar
blueflyer blueflyer is offline
Default curious
Just curious, not that it matters at all, but why do you check your tire pressure based on hobbs when all you other maintenance times are based on tach? I guess that what the "h" and "t" mean...
Old 01-01-2018, 06:49 PM
I have one sorta like that, but more of a summary. IIRC, it shows the following:
BFR Due XX/YY
Medical Due XX/YY
Condition Inspection Due XX/YY
Oil Change Due XX/YY or ZZ hours
ELT Due XX/YY
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 01-02-2018, 05:23 AM
scrollF4's Avatar
Tracking tire pressure checks by Hobbs just makes sense to me, since it’s based on actual operating time rather than time adjusted for engine ops tempo. It works for me.
Scroll
Old 01-02-2018, 05:39 AM
rleffler's Avatar
rleffler rleffler is offline
There are other alternatives that may be less expensive than the standard white board. I have a 3' x 6' magnetic whiteboard sheet that sticks perfectly to my hanger wall (assuming you have metal walls). These come in all kinds of shapes and sizes, to also include rolls in about any length you want.
This thread has given me some ideas on how to make my board appear more organize than in it's current state.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 01-02-2018, 05:59 AM
Planecrazy232's Avatar
Planecrazy232 Planecrazy232 is offline
I have my chart in Excel format saved in my dropbox and available anywhere, anytime.
Anthony
RV6-A "Aluminum Mistress"
Too many hobbies- not enough time.
2016, 2017, 2018, 2019 donor and happy to do it.
Old 01-02-2018, 06:56 AM
Walt's Avatar
Walt Walt is offline
I would suggest tire pressures be checked based on calendar time, they really don't care about tach or hobbs time.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 01-02-2018, 02:42 PM
scrollF4's Avatar
Walt,
What interval do you use?
Scroll
Old 01-02-2018, 05:15 PM
rolivi's Avatar
rolivi rolivi is offline
We've all had the same conversation with our tires.
"Hey tire, you're too low. It's only been 16 hobbs hours"
Tire says, "hiss". Or worse, it was saying "hiss" when we weren't around to hear it.
Rob
RV-6A (Purchased)
2019 Dues Paid, of course
Old 01-02-2018, 05:50 PM
Walt's Avatar
Walt,
About every 2 months for me.
