Old 01-01-2018, 06:49 PM
Slouis Slouis is online now
Default Rv6 rear wing spar.
I am looking for some advice on removing the rear wing spars from a completed pair of rv6 wings. I need to replace the two inner pieces (W-607D and W-407) on both wings spars because they were drilled incorrectly by the previous owner setting the wing incidencd. It appears that they were not satisfied with the wing incidence so the drilled a second hole on each seide to correct the wing incidence and the two holes overlap creating a long “figure 8” looking hole. I was informed that this bad hole makes it not airworthy. Any advice would be greatly appreciated.
Scott Louis
RV 6 in progress.
Scottelouis at gmail
Old 01-01-2018, 06:55 PM
Contact Vans and see if a repair is possible.
Old 01-01-2018, 07:00 PM
I have already spoke to vans and they sold me the above parts and told me that they need to be replaced. If i can’t determine the best way to replace these i will reach out to vans. It appears from what if understand from the construction plans i may need to remove the main skins on the trailing edge of the wing.
Old 01-01-2018, 07:14 PM
Billythekid Billythekid is offline
Default pics
can you post pics.
Old 01-01-2018, 07:46 PM
You should be able to drill out the rivets on the offending parts, and drill out some skin rivets to gain access to rivet new ones. If you're not extremely proficient, you might want to find a good sheet metal guy to help. This is a critical area, and you don't want to mess it up taking it apart or putting it back together.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 01-01-2018, 07:58 PM
Default Rv6 rear spar
Here are some pictutes
https://photos.smugmug.com/My-First-...D41C4B23-M.jpg
https://photos.smugmug.com/My-First-...DDF3AC40-M.jpg
Old 01-01-2018, 08:13 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
The builder of my RV-4 did that except the holes overlapped. Fortunately only one wing. Discovered it when the wing had to come off after the mechanic put a jack through the wing.
RV-8 (steam gauges), RV-9A at KSAV (Savannah, GA; dual screen G3X with autopilot, GTN 650)
Previously RV-4, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2018 dues paid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 01-01-2018, 08:46 PM
How did you correct the problem
Old 01-01-2018, 08:55 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
All I can say is "WOW!" Who would do this?
I'd take a good hard look at any other critical pieces, parts and assemblies on this plane.
2017 Dues paid!
Old 01-01-2018, 09:00 PM
Already done. This how we found this going over the plans amd the parts already built.
