Old 01-01-2018, 02:12 PM
SMO's Avatar
SMO SMO is offline
Default WTB: Red Cube
I am going to replace my Floscan with a Red Cube. Anyone have a spare kicking around they want to sell? Will be in Palm Desert from Jan 8 to 27 so can have it shipped there.
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
Old 01-01-2018, 02:19 PM
bkervaski's Avatar
I have an extra, new in the wrapper, PM me an offer!
Reserved: N196
Progress: Firewall Forward
Old 01-01-2018, 02:29 PM
rv8ch rv8ch is offline
Default floscan to red cube
just curious - why changing them? I thought they were functionally equivalent, just a different shape?
Mickey Coggins
http://rv8.ch
Old 01-01-2018, 03:31 PM
SMO's Avatar
SMO SMO is offline
I have had a couple of instances where my fuel flow is displaying higher than expected (eg: 14 gph vs 10 gph). Upon pulling the mixture to the desired flow the engine runs rough and I realize I am way lean even though the gph indicates otherwise. No evidence of leakage anywhere. My transducer is in the tunnel between the boost pump and the engine driven pump. I have decided to change the location to between the servo and the spider, and at the same time change out the transducer. I expect this change to resolve the issue, but I won't know if the problem was the transducer or the location.
As far as functional differences, some are discussed in this thread http://www.vansairforce.com/communit...ad.php?t=54058
Mark Olson
1987 RV-4 Sold
Old 01-01-2018, 03:39 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
And that might be your problem. It needs to be located AFTER the engine driven pump. Otherwise the pump pulses cause the impeller to oscillate and the transducer to indicate high. Especially if you use the boost pump a lot in a particular flight.
This has been discussed a lot in the past.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
www.PuertoRicoFlyer.com
