Old 12-30-2017, 09:01 AM
bobnoffs bobnoffs is offline
Default welding alum tubing
hi all,
i am fitting aluminum flanges and a piece of tubing and need a way to lock it all in position to take to the welder. i was thinking of a little epoxy along the joints in a few places. after the welder tacks it rigid he could clean off the epoxy with a wire wheel. anyone got any other ways to do this? think my way will work?
thanks for any input.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying
RV-12 kit as of 9/13
Old 12-30-2017, 10:43 AM
kentlik's Avatar
kentlik kentlik is offline
Originally Posted by bobnoffs View Post
hi all,
I weld quite a bit and would not want to clean epoxy off particularly...
A simple single-use wood JIG would be preferable to contaminants on the metal.
IMHO
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 12-30-2017, 11:10 AM
rackley16 rackley16 is offline
I agree with Kentlik. I too, weld a lot at work for a living and the hazards of burning substances that are not cleaned off are very hazardous. The risk of some epoxy getting in between the joint and not be accessible to proper cleaning is a real danger.
The jig is one way.
Alternately, you could fit the parts really well and mark them in place so you just line up the marks when taken to the welder and tack weld them. Return home and test fit. If all is well, go back to the welder and have him finish the welds.
None of it is 100% reliable as the metal will move and distort during the welding. The only way to do it once reliably is to hire a portable welding service, while the pieces are firmly clamped into position and fully welded in place.
Good Luck!
Ben
2018 dues paid.
RV7 empennage acquired and the "journey" has officially begun.
Old 12-30-2017, 11:14 AM
maniago's Avatar
maniago maniago is offline
IMHO
I dont weld a lot, but enough to be called an above average hack and I agree with kentlik. AL is temperamental with cleanliness (not as bad as SS however). I suppose the welder could grind out the epoxy- its ok, but not optimal.
You ought to ask the welder what he can tolerate really. It also depends on what the part is being used for, or what stresses it'll encounter. AL welds are not as strong as the parent metal (steel is the opposite), so application will play a part in his decision about what you ought to do for him.........
Mani
Mustang II (FoldingWing) "Firewall Fwd stage.Yea!" IO-360B1E,RSA,C2YR-BF/F7666-2,Superior sump,James; 2xHXr,MiniX,EIS,480,327,240,SL30,(maybe)Echo; SteamAlt,AS,VSI
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Dec2017
Old 12-30-2017, 11:15 AM
mbauer mbauer is offline
Default Aluminum Cleaning
Don't use the epoxy!
Aluminum needs to be extremely clean.
Using stainless steel wire brushes is step One> Step Two-acetone wash.
Learning how to TIG aluminum right now.
At first; Could not get the ARC started. Cleaned the aluminum again, and was able to finally start welding.
Best to ask the welder what he prefers/transportation ideas....
Mike
Mike Bauer
2017 Dues Paid
2018 Dues Paid
Old 12-30-2017, 11:47 AM
gasman gasman is offline
I would mock up a wooden part to fit in final location. glue all parts. Then make a Jig to fit the wooden part. Fit your finished parts to the jig and weld up...... Now you can make the same part over and over.
On location is far easier but not always practical.
Update...... If there are only a few simple parts, just jb weld them and then make the jig and another set of parts for the finished item.
VAF #897
2017 =VAF= Dues PAID
Old 12-30-2017, 12:10 PM
Marc DeGirolamo's Avatar
Marc DeGirolamo Marc DeGirolamo is offline
Default AL welding
hi all,
Don't contaminate the AL with epoxy. Use hose clamps clamps or secure it to plywood somehow....?? Hard to say with out seeing what you have.
Marc DeGirolamo
Canadian..Rv-4 Flying
VAF # 144
Old 12-30-2017, 01:06 PM
John-G John-G is offline
Bob,
I think you would be better served if you were to use a few small strategically located pieces of duct tape to hold the parts together so the welder can lay down a couple of tack welds on the parts. Once the parts are secure, the tape can be removed and any leftover adhesive residue removed with a good scrubbing using Acetone or Alcohol prior to finish welding.
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2018
Old 12-30-2017, 03:35 PM
azrv6's Avatar
azrv6 azrv6 is offline
Agree with all of the comments above regarding jigs, anything will do to hold it until tacked. Depending on the shape of the parts, there is also PET welding tape https://youtu.be/KV3rLBetM4I. Have also seen parts "tacked" with the smallest amounts possible of cyanoacrylate (crazy) glue. The torch just vaporizes the tacks. YMMV.
Dave Binkley
RV-6, O-360-A1A, C/S
1932 Monocoupe 110, Warner 145 (http://gobinkley.com)
Sedona, AZ
Old 12-31-2017, 05:21 AM
thanks guys , a lot of info i never thought of.
the u tube with pet tape was good. a fabricator demonstrates several tapes for holding pieces. masking tape even works but clean up is a pain. the pet tape doesn't burn and comes off with no residue left behind. gotta get some of that.
Bob Noffs
n. wi.
