Old 12-28-2017, 07:39 PM
psychose psychose is offline
Default Aerocanopy for RV8
Hello folks,
Hope you all had a good Xmas.
Went flying on Tuesday to do a short aileron rigging test. Some time during the flight heard a bang, had no idea what it was. Headed back to airport. Once back in the hangar, I noticed the huge crack in the canopy. It had continued from an incipient crack I had stopped-drilled during the build. It had held fine up to this point, but I guess the extreme cold temperature was too much for it this time.
Vans sells a new canopy for 1200$. Aircraft Spruce sells experimental canopies by Aerocanopy for 675$. Anyone have experience with these canopies? Would appreciate any advice.
For the record, I'm NOT looking forward to installing a new canopy...
Thanks in advance,
Normand
RV8 C-GNGN
Old 12-29-2017, 10:02 AM
Red Mtn flyer Red Mtn flyer is offline
Default canopy repair
No experience with that vendor -- but consider repair. Obviously, we don't see what you are looking at, but:
https://www.polyvance.com/pfxcanopy.php-1
Ben K.
RLSA - A,G,W/S; Falco F-8L
50 yrs of flight and counting
Dues paid 2017, 2018
Old 12-29-2017, 03:48 PM
Hello Ben,
I have seen this web site and am considering my options. Mine is a very clean crack and so far I've tried methylene chloride but there is a small gap caused by the stress that provoked the crack in the first place. I will probably need to use a thicker solvent to fill the void.
I'm still considering the replacement option as I doubt I will be satisfied with a repair that is less than perfect...
Thanks for rhe suggestion.
Normand
Old 12-29-2017, 06:50 PM
Scott Hersha Scott Hersha is offline
Did the original crack emanate from a hole/pulled rivet used in the initial installation?
SH
RV-8
Cincinnati, OH/KHAO
Old 12-31-2017, 09:04 AM
Hello Scott,
Yes, the original hole was a crack emanating from a pulled rivet hole. I probably did not enlarge the hole enough during the build.
regards,
Normand
Old 12-31-2017, 10:06 AM
Northernliving Northernliving is offline
Hi Normand, I believe that Lance Logan Stuart, FL Plane based at X58 purchased Todd's tools and is now making canopies. Username judoka5051. That might be an option.
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
RV8 - The Dream - Under Construction
Old 01-03-2018, 07:38 AM
Hi,
Yes I read that in some of the posts. Also read that Lance does not produce canopies using 1/4 inch acrylic as Todd apparenly did, but 3/16 inch as Vans and Aerocanopies do. So not sure if there is still a quality advantage.
I've ordered a Plastifix kit from ACS and will give it a try. It may keep me satisfied until I get the a/c painted.
Cheers
Normand
RV8 C-GNGN
Old 01-05-2018, 07:28 AM
judoka5051 judoka5051 is offline
Default Canopy thickness...
Good morning all,
Just stumbled onto this thread. Todd primarily used 3/16" material for all canopies. He would make a 1/4" canopy if you insisted. I bought the canopy for my 8A from him and originally want the 1/4 material. He talked me out of it, explaining that it was quite a bit heavier. He happened to have a 3/16 in stock at the time, so I bought and installed it with sikaflex. Messy, but worth it!
I'm fine with the 3/16" material, but, I plan on trying to form just the windshield portion out of 3/8" for those RV8 flyers concerned about bird strikes. Won't do me a bit of good though, mine's a fastback tip-up...
Regards, Lance
P.S. If you see this Doug, I'd like to advertise here. I emailed you a while back. You probably get a million a day though, so good luck finding it!
judoka5051@yahoo.com
561-779-9932
Lance Logan
Stuart, FL
Plane at X58
Scratchbuilt Biplane
Preceptor N3 - Sold
Zenith Zodiac 601HD - Sold (good riddance)
Kitfox IV - Sold my share, but loved that plane
RV8A Sold! Loved the plane, but not the nosewheel!
RVX (RV6/4) Sold
RV8 Project purchased (Can't help myself)
Old 01-06-2018, 06:23 AM
ronschreck's Avatar
ronschreck ronschreck is offline
Exclamation Beware the cold.
Wow, that's the third cracked canopy I have heard of this week! The bitter cold that has enveloped most of the nation this week is bringing a rash of troubles to many. My canopy cracked in September on a 75-degree day! I have installed a new canopy with Sikaflex and hope to never have to do it again. Just curious, has anyone ever heard of a Sikeflexed canopy cracking?
Ron Schreck
IAC Director and National Judge
RV-8, "Miss Izzy", 2100+ RV Hours
Track Me *** Gold Hill Airpark (NC25)
VAF 2018 Donor
"He who demands everything that his aircraft can give him is a pilot; he that demands one iota more is a fool."
Old 01-06-2018, 06:48 AM
Michael Henning Michael Henning is offline
I have a “Todd’s” canopy on my -4. Has anyone taken over the operation or filled the void from Todd?
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
