Old 12-28-2017, 05:07 PM
Flienlow Flienlow is offline
Default Building an RV
After writing pages and pages... I have decided I will just ask this:
How much of building an RV Aircraft (RV-10) is ASSEMBLY vs. DESIGN and FABRICATION?
You poor unfortunate souls are going to teach me to build an airplane one stupid question at a time.
Old 12-28-2017, 05:20 PM
Kyle Boatright Kyle Boatright is online now
There is relatively little design and fabrication unless you are changing things from the plans. There is a lot of prep work - fitting, drilling, deburring, a fair amount of assembly, and a lot of fit, adjust, lather, rinse, repeat. There is also a substantial amount of thinking about systems and systems installation.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 12-28-2017, 05:28 PM
rzbill's Avatar
rzbill rzbill is offline
What Kyle said.
Stick to the plans and the airframe has little to no design work.
BUT, also as mentioned, the systems installation (electrical mainly) is not detailed by Vans
like the structure and it is up to the builder for the most part. There is a lot of decision making even with the purchase of a prefinished panel from a reputable supplier.
Bill Pendergrass
RV-7A: Flying since April 15, 2012. 750hrs
YIO-360-M1B, mags, CS, GRT EX and WS H1s & A/P, Navworx
Unpainted, polished....kinda'
My RV Construction Page
Old 12-28-2017, 05:33 PM
Zuldarin's Avatar
Zuldarin Zuldarin is offline
Default Local builders
Hey Justin, there are a large number of RV builders in the Puget Sound that would be more than happy to show you what building an RV is all about. I've built a 9A and am building a 10 now but I live in the Snoqualmie Ridge neighborhood which is a bit of a drive for you. If you ever find yourself in the area though I would be happy to show you whats involved.
Darin
Snoqualmie WA
RV-9A Flying as of 03/2015
RV-10 Building - Fuselage
www.DarinAnderson.com
2018 donation sent!
Old 12-28-2017, 10:11 PM
I would love to check out your project!
Old 12-29-2017, 11:05 AM
Super Moderator
You are so close to the factory, have you thought about making a visit. Really wonderful people there who will answer all of your questions, and give you the tour of a lifetime. Be careful with taking a demo flight. Your life will change forever.
Vic
Vic Syracuse
Van's East Coast Representative
www.Baselegaviation.com
Old 12-29-2017, 06:45 PM
That is a great idea. Funny thing, I just finished a tour of cub crafters this weekend. Beautiful Airplanes and great folks there. But man oh man they are pricey.
Old 12-29-2017, 08:01 PM
leok leok is offline
All of the aluminum structure requires only assembly. You will need to design and add small items like doublers for antennas, instrument mounting. The instrument panel is a single slab of aluminum. Cutting holes and mounting avionics is for you to figure out. Further enhancements are yours to figure out as well.
Major flight systems are all designed and need only installation with the exception of avionics and the electrical to support it. You will need to choose the electrical architecture, wire routing and how to install into the airplane.
Lighting, both flight and interior, antennae placement, any engine features beyond the Lyc IO540 such as electronic ignition is again yours to figure out.
The interior is very basic with front seat foam and seating structures. Upholstery, including rear seat foam, and enhancements and creature comforts will be on you.
In fact, when I sat in the Vans RV-10 demo at Oshkosh, I almost decided not to build one because it was too Spartan for my taste. Then seeing the beautiful examples from builders, I saw the amazing potential of personalization possible.
My build will end up approximately 50% Vans plans and 50% stuff I decided I want to do.
Building my RV-10 since Oct 5th 2014
Flying .. once I figure out how to pay for everything
http://www.mykitlog.com/leok
RV Hotel
Dues paid 2018
Old 12-31-2017, 12:51 PM
Not speaking of you personally, but the Royal "you".... How do you know the stuff that you decided to do will work, and wont be dangerous?
Also, another build question:
Would it work to have 2-3 buddies help you with a build, or is building a plane something you need to do alone with little intervention?
Old 12-31-2017, 01:03 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
Originally Posted by Flienlow View Post
. SNIP
The vast majority of the work you can do yourself. There are however specific times when you need at least one helper (some rivet work in particular). I’d say this will be less than 10% of a slow build.
That said - it is very nice to have a helper for the huge priming session and such. On my first RV build, there were two others builders at about the same place I was in the build that were close to me. We met as needed when one of us needed a hand. The unspoken rule however was the builder getting help was 100% ready to go; parts clekoes, tools ready, coffee made, etc. The #1 sin was wasting another builder’s time. Another aspect of this was as we got to the end of the builds, each of us became “the guy” for a partiqular skill. I was the wire and avionics guy, we had a “scrounger” as well as a paint and fiberglass guy.
You will spend a boatload of time reading, looking, reading, etc. before you pick up a tool. This is best done by yourself.
