Old 12-28-2017, 11:12 AM
JDA_BTR JDA_BTR is online now
Default Beringer Mineral Oil
I need some of the mineral oil to the milspec Beringer requires, Brayco Micronic 881 is what I found. A gallon can be had from Beringer USA for about 70 plus shipping. Grayco has it for 46 a gallon but 2 gallon minimum (70 min order).
So does anyone want me to ship them a gallon for what it costs me plus shipping? Does anyone have a gallon they want to send me?
Otherwise I'll probably just get the 2 gallons from Grayco and sit on the surplus.
N1463 seems a good number....
Old 12-28-2017, 12:08 PM
F1Boss's Avatar
F1Boss F1Boss is offline
Default Google is your friend!
I checked on the specs of MIL-PRF-87257B and Aeroshell 51 complies. I'll wager Synth ATF (Mobil 1 for example) will do fine - think of what you're gonna do when your out in the boonies and you need fluid - synth ATF is available anywhere.
Auto type brake fluids are right out! Do no use any of those, except the silicon types.
Best,
"Not everyone needs a Rocket. Some folks, however, shouldn't live life without one.
You know who you are."
Budd Davisson, 1997
Old 12-28-2017, 01:20 PM
Default Since the ATF discussion
came up a few weeks ago- I inquired to Beringer about the use of ATF in their systems. As of today, I have NOT gotten an answer. But when I do, I'll post it here.
Tom
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 12-28-2017, 01:35 PM
Good tip; seems the Aeroshell 51 is the right MILSPEC.
The Aeroshell 51 is 87257B and the Brayco is 87257A. I wonder what the "A" and "B" are. Looks like the B is just the latest revision:
http://everyspec.com/MIL-PRF/MIL-PRF...57B.006018.PDF
The shell fluids PDF: https://www.shell.com/business-custo...hydraulics.pdf
Old 12-28-2017, 01:55 PM
Walt's Avatar
Walt Walt is offline
I've used the standard MIL-PRF-83232 (Royco 782) in their systems with no issues. The fluid they call out is for use in ultra cold climates/high altitudes.
AeroShell Fluid 51 is recommended for use in aircraft, ordnance and missile systemsoperating from –54°C to +135°C. This fluid should be considered for use in auto pilots, shock absorbers, brakes, flight control systems, hydraulic servo-control systems and other systems using synthetic elastomer seals. This fluid is especially recommended for use in high altitude aircraft that normally operate with extended loiter times and high endurance levels such as UAVs and ELINT systems.
AeroShell Fluid 51 is compatible with AeroShell Fluids 4, 31, 41, 61 and 71 and can be used in systems designed to operate with MIL-PRF-5606, MIL-PRF-6083, MIL-PRF-83282 and MIL-PRF-46170 fluids.
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 12-28-2017, 07:14 PM
Itís likely ok but a Belinger rep specifially told me no substitutes were acceptable to them.
Old 12-28-2017, 07:46 PM
wirejock's Avatar
wirejock wirejock is offline
Default Brake fluid
I was planning on using Royco 782 as well.
http://m.aircraftspruce.com/catalog/...?clickkey=4008
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 12-29-2017, 06:03 AM
MED MED is offline
I sent you a pm. I'll split with you.
MED
140236
N435MD reserved
Old 12-30-2017, 08:17 AM
Walt's Avatar
From the latest Beringer MM:
http://www.beringer-aero.com/en/file...int-manual.pdf
CAUTION: Standard MIL-H-5606 Brake f luid is replaced by f ire resistant f luid:
MIL-PRF-87257 and MIL-PRF83282, make sure that only those brake f luids are used.
Old 12-30-2017, 03:09 PM
N54SG N54SG is offline
I've been running Royco 782 in Beringer brakes for years, no problems. Plus it doesn't smell as bad as 5606!
Lancair 360
Superior XP-400 SRE
Best Average Race Speed: 279.686 mph
Building Lancair Super Legacy
TIO-580-EXP
N54SG.com
