Old 12-26-2017, 12:04 AM
rv8ch rv8ch is offline
Default You can fix it!
Originally Posted by Capt View Post
This is an interesting thread, can learn a lot about this stuff Had a look at Stein's website, impressive.
The one thing I notice with Vans A/C & no doubt a lot of other kit builder designs is that the panels are all over the place. I've been looking for an 8 for ages now inc 7's & the one thing that puts me off most of them is the panel! It's like some stand back throw a dart & where it lands is where the next instrument goes. A couple I've looked at have functional panels but have issues elsewhere. I guess for me coming from a commercial flying background one gets used to standardization, something that doesn't exist in the experimental world. Still it's interesting to see what's inside the heads of Vans owners:-)
Fixing the panel to be the way you like it is easy! I agree with you on the lack of standardization. I have not been able to find any research on panel layout with an EFIS, particularly things like where to put radios, toggle switch groupings, etc. Also, when you throw a tablet into the mix, it becomes even more complex. It would be interesting to hear your views on the perfect panel.
Mickey Coggins
http://rv8.ch
Old 12-26-2017, 01:39 AM
control control is offline
As for layout, an interesting example is Diamonds DA40 and DA42 panels.
The first impression from new to the AC pilots are usually something like "what a mess!!!". After going thru the startup checklist and using the AC in the air one realizes that it is actually very functional and clever.
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
Old 12-26-2017, 12:22 PM
Captain_John's Avatar
Look into the Approach Fast Stack hub. It utilizes custom harnesses that you spec out and all you do is wire the feeds, grounds, antenna leads and servos to the ends of the harnesses.
It worked out GREAT for me!
CJ
RV-7 Flying - 810 Hours in 3 Years!
Old 12-27-2017, 10:24 AM
Adam W Adam W is offline
Default Steinair
Stein air has been great to work with
Another vote for them
Adam Wachtel
Thornhill Ontario Canada
Building RV7 #70770
Wings done
Empenage done
QB Fuse done
Finish kit underway
Vans Airforce Dues Paid
Flying Piper Supercub PA18 150
Flying Cessna 414A
Old 12-27-2017, 11:26 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
Default Be careful what you wish for
All,
I would like to provide a contrarian point of view on wiring your plane, panel and panel layout.
With the current EFIS offering (like SkyView) the vail of mystery has been removed from this process. I offer most will do themselves a favor to at least try to do all your project wiring yourself. You will then be prepared to go back in when time comes for modifications. The only caveat might be getting a wire harness for the TSO GPS box (e.g. GTN-650) as many shops will not sell you a box without a harness. As it turns out however, ARINC modules translates to just a few wires going to a box like the GTN-650.
As far as panel layout, I would hate to see any push to a standard panel. The panel should reflect the best examples of other builders as seen through your eyes. The corollary to this point is after you fly, you will want to change something. As such, build the panel assuming it will be modified. Here is where I recommend you not blow a big wad of money on stuff like carbon fiber or silk screening unless your wallet is so thick you donít care. Over 15 years for my RV-8A there where five panel mods, two required buying a new $22 piece of aluminum from Vanís, new holes & paint. For the RV-10 the first panel lasted less than a year. The second panel is still there but two new SKyView modules were added.
One other point about buying wire harnesses. While the good shops know what they are doing, some may not. I helped a builder with his pretty panel from a shop that involved more rework to install than just starting from scratch. The panel works, but the owner is now at the mercy of finding someone to help if anything goes wrong because he does not know how it all works.
In my first life detailed system knowledge and demonstrated proficiency was required before touching anything on the plant. Translating this approach to RV building has served me well.
Old 12-30-2017, 01:40 PM
dave4754's Avatar
dave4754 dave4754 is offline
Default Frustrating but does seem a good thing to do.
As typical this is a very tedious and frustrating thing in my RV seven. However it has turned out easier than I thought and with the help of some previously made up cabling from diamond Skyview I donít to Skyview touch system complete with intercom radio auto pilot and transponder appears to be coming along nicely. One does have to consider it does take hours and hours to do. So if you havenít those hours digging that wallet and I would suggest Stein he was very helpful on my purchasing some great used equipment.
Dave Cobb
=VAF=2018 Donation - and a bit extra for great work!
Empennage RV 7 - Tipper
Wings complete
Fuse nearing completion, Canopy complete
AME reviewed and repaired O-320-Lyc installed
Old 12-30-2017, 07:00 PM
RV7 To Go RV7 To Go is offline
Default Panel and wiring
I tend to agree with the point of doing your own panel and wiring. After learning sheet metal work, fibreglass, hardware, engine install etc why not the electrical too? Great knowing how it all went together. I think the most difficult part is the planning due to all the choices required...VFR or IFR, glass or steam (and if glass which brand?), how much redundancy, breakers, fuses or VPX etc etc. It is not a hard job but it is tedious and time consuming. The Aeroelectric Connection book gives great info and sample wiring schematics as do other aircraft wiring books. If you can read the electrical schematics for your selected equipment you can wire it up. I know I did on mine and knew nothing about it to start. Everything else you need to know is on the net and you may have an electrical guru on the field to ask for help. It's certainly a great feeling turning on the master for the first time and lighting things up!
Al
Old 12-31-2017, 05:05 AM
SR2500 SR2500 is offline
I did my own wiring and it wasn't that difficult. However, I strongly recommend you have Stein make you a pin out diagram for your avionics. Mine was approximately $400 and it was worth every penny. It clearly showed how to ground each wire, where and how to use shielding, and was a simple as make a wire from pin 12 on this gizmo to pin 4 on this one. In addition to the avionics, I used one of Bob Nuckolls diagrams from the Aerolectric Connection to do the primary electrical wiring. I also purchased the primary electrical materials from B&C. They list everything necessary for each Nuckolls diagram on their website. Both B&C and Stein were quick to answer phone calls when I had a question.
All in all, very enjoyable. You can pull one or 10 wires per evening in the warmth of your home.
Jerry Folkerts
Jerry Folkerts
Pietenpol, built and sold
Cygnet SF-2A, built and flying
Murphy Super Rebel, building
Vans, next build
