Old 12-15-2017, 08:20 AM
Stockmanreef Stockmanreef is offline
Default Firewall insulation
I have been reading a bit on insulation of the firewall. Has anyone done this for their 14 and if so, can you post how you did it, when you did it and pictures.
Ken
Ken Stockman
Midland, MI
EAA Chapter 1093 member
RV-14 (serial number 140073)
N73XP (at least that # reserved now)
Old 12-15-2017, 03:04 PM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
I did this on my -14. First i ordered stainless steel (.003 x 24” x 48”) this was $33 plus shipping on ebay. Then i got fiberfrax from ACS of 1/8” thick. I cut the fiberfrax around all know holes and about 1/4” away from where the engine mount touches the firewall. The stainless at 24” is not tall enough to cover entire firewall but because my plane is a tailwheel, the engine mount has a large cross member along the bottom. With that issue and the cabin heat registers both not getting coverage, only a small horizontal strip is unprotected with the secondary layer. I installed these when i was ready to install my engine mount. Between the enginge mount/ two firewall pass thrus / and brake reservoir the sandwich of fiberfrax and stainless stays put pretty well. I did use a few stainless pop rivets to the sides of the tunnel and might do a few more on the top part depending on necessity. I then used 3m 2000 firebarrier as a caulking to seal up all edges and holes. So far ive been very happy with this slight deviation from plans as i feel is does cost or weight much and adds a margin of safety and comfort.
Rob Lasater
Rv-14 emp/fuse done working on wings and finish
Paid dec 2017
Old 12-15-2017, 04:11 PM
DanH's Avatar
DanH DanH is offline
Rob, did you run a bead of Firebarrier 2000 in the firewall flange corner before applying the fiberfrax and stainless foil?
Dan Horton
RV-8 SS
Barrett IO-390
Old 12-15-2017, 04:44 PM
Bill Boyd's Avatar
Default Timely reminder, Dan
... working on this step tonight.
Thanks for all the firewall insulation ideas and testing!
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 12-15-2017, 05:30 PM
Av8rRob's Avatar
Yes Dan, I forgot to mention that step
Rob Lasater
Paid dec 2017
Old 12-15-2017, 08:44 PM
JHartline JHartline is online now
Default Now I’m curious
[quote=DanH;1225878]Rob, did you run a bead of Firebarrier 2000 in the firewall flange corner before applying the fiberfrax and stainless foil?
Ok...I’ll bite...why add the fillet?
I did my firewall using your diagram but I never thought to ask the reason for the first fillet.
James Hartline
Carrollton, GA 5GA2
RV-14 - Finish and FWF in progress
T-Bolt IO-390
Maule MX7-180
Old 12-15-2017, 09:36 PM
Bill Boyd's Avatar
Default and I'm embarrassed
... realized as I was about to lay the first fillet that I can't insulate the firewall until I rivet the forward top structure on - and that's not happening until I'm done installing the avionics goodies in the panel and sub-panel. About a year from now. Oops!
Bill Boyd
Old 12-16-2017, 12:17 AM
Av8rRob's Avatar
I have same issue. If you look closely, you will see the edges above the engine mount are still lose. I only attachech the bottom portion at this point. Its on the to do list.
Rob Lasater
Paid dec 2017
Old 12-16-2017, 05:19 AM
DanH's Avatar
[quote=JHartline;1225930]
Need a bead over the punched holes and slots in the flange corner to ensure the fiberfrax binder (the glue that holds the felt together) doesn't outgas into the cockpit when heated. The desired path for the outgas is forward, through the overlap seam, which is why it is in the center, and covered with easily melted aluminum tape.
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-03-2018, 12:24 PM
Aluminum Aluminum is offline
Thank you all for sharing, great advice.
I found out that McMaster stocks a much wider selection of fiberfrax material:
https://www.mcmaster.com/#93285K18
Search under "insulation" then "Ultra-High-Temperature Ceramic Fiber Insulation Sheets and Strips".
Dan V
'91 Zodiac flying since 2013
RV-14A in progress
2018 dues worth every penny
