Old 12-13-2017, 08:52 PM
RV-4 RV-4 is offline
Question INFINITY STICK GRIP VS RV-4 STICK
Hello All
I will be installing an Infinity Stick Grip in my RV-4 over the winter and I have a few questions for the ones of you who have done the same thing before...
1.- Did you have to cut the stick so that the Infinity grip did not hit the panel versus the standard Vans stick grip?? ( My panel is 3/4'' lower than standard )
2.-Where did you guys run the wire bundle.....Inside the stick or on the outside ???
If on the inside did you have to re-inforce the stick after drilling an exit hole for the wires??
3.- Did you have to cut the slot as per the Infinity instructions if running the wires inside the stick??
Thank you for your feedbacks..
Bruno
rv4@videotron.ca
P.S: If any of you have pictures of your install, I'll be glad to look at them if you don't mind sending me some...:-)
2018 Due paid gladly
Old 12-14-2017, 06:47 AM
Skysailor Skysailor is offline
I have the Infinity grip in my 4. You will probably have to shorten the stick slightly to prevent panel interference but the wires will run inside easily and you do not need to cut the slot.
RV4
Paid through 2018! How about you?
Old 12-14-2017, 07:08 AM
Veetail88's Avatar
Veetail88 Veetail88 is offline
See this thread on reinforcing the hole in the stick for wiring. Lots of reading complete with finite element analysis. http://www.vansairforce.com/communit...ighlight=Stick
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 12-14-2017, 04:16 PM
Thumbs up INFINITY GRIP ON AN RV-4
Hi Mark
That's what I thought but wanted to be sure...How much did you cut yours for it to fit??
Thanks Jesse, I'll have a look at the link..
Cheers
Bruno
Old 12-15-2017, 08:20 AM
I just cut and test fit until I got the clearance I needed. I do not remember the amount removed.
RV4
Old 12-15-2017, 12:03 PM
Default INFINITY GRIP ON AN RV-4
HI Mark,
I plan on doing the same...just need the weather to warm up a little before I venture to the hangar..It's -20 C here today..
Cheers
Bruno
Old 12-15-2017, 12:52 PM
scottmillhouse's Avatar
scottmillhouse scottmillhouse is offline
Let me know if interested in a previously installed on sticks but unused set. Bought a 7 project with them installed and I want most of my controls on the panel so these are overkill. Have two handles, extra wiring and the relay board all unused. PM or email me and I'll save you some money.
Scott- 2018 dues paid
Got medical back, now building a 7A; N579RV reserved, new engine installed, doing FWF, instruments & finish painting.
RV-12 #120515, N319RV 1st flight 12/2015 now over 270 hours.
RV-9A, 536 hours sold, RV-7 sold, Kitfox sold
Old 12-15-2017, 04:42 PM
merlin3 merlin3 is offline
I am interested in one
Justin
Rv-6, o360, whirlwind cs prop, old paint and panel
Rv-4,o-320,prince prop, mgl avionics screens - sold
Old 12-15-2017, 11:18 PM
AX-O's Avatar
AX-O AX-O is offline
I think the diameter on the rv-4 stick is different than the one on the side by side rvs. It has been a while since i installed mine.
Axel
RV-4 fastback thread and Pics
West Coast Ravens
VAF 2018 paid VAF 704
The information that I post is just that; information and my own personal experiences. You need to weight out the pros and cons and make up your own mind/decisions. The pictures posted may not show the final stage or configuration. Build at your own risk.
Old 12-19-2017, 03:02 PM
Thumbs up RV-4 STICK
Hi All
''I think the diameter on the rv-4 stick is different than the one on the side by side rvs. It has been a while since i installed mine.''
Mine in my -4 is 1'' in diameter...don't know about the -7...
Bruno
