Old 12-13-2017, 08:54 AM
dromuald's Avatar
dromuald dromuald is offline
Default Flap linkage bolt
I thought I would share this discovery since I appreciate other posts when members share important issues. I was performing my annual condition inspection with my local A&P. I decided to pull the interior side panels of my RV-8 to inspect the flap linkage. I had recently made the mistake of taking off with full flaps and although I was confident I didn't overspeed the flaps I thought it would be worth a look. To my surprise I found that the nut on the bolt which connects the flap motor to the linkage almost completely backed off. Although it has a nylon insert this nut could be turned with my fingers.
I have owned the a/c for five years (not the builder) and regret that this was never checked on my previous condition inspections. I can't vouch for whether or not the nut was installed properly but I do see some evidence that a wrench was used on the nut prior to this photo.
Although I have no idea as to why this nut came loose I thought it would be something of interest to this forum.http://s899.photobucket.com/user/dro...tml?sort=3&o=0
___________________
Dave Romuald (MSN)
RV-8 655CL
Old 12-13-2017, 09:18 AM
vic syracuse vic syracuse is online now
Super Moderator
Good catch. I doubt it came loose. I have seen more than one nut on an airplane that was never tightened.
Vic
Vic Syracuse
Van's East Coast Representative
www.Baselegaviation.com
Old 12-13-2017, 10:24 AM
NYTOM NYTOM is offline
Default Probably missed torquing in construction.
I agree with Vic on this one since I just completed my own flap installation. If the bearing is properly installed, the bolt should never have the opportunity to turn at all if torqued to specs.
Tom Norwood
Classic "Short Tail Six" A Model N822PM (Res)
99% done, 1% to go! Oh so close!
Mel's Avatar
Mel Mel is online now
Vic
My self! What bothers me is that lately I've been finding loose nuts with torque seal on NEW aircraft.
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 12-13-2017, 03:40 PM
Super Moderator
That's mind-boggling. I don't think someone understands the objective of using torque seal!
Vic
Vic Syracuse
Old 12-13-2017, 04:10 PM
chrispratt's Avatar
chrispratt chrispratt is offline
Super Moderator
Vic
Oh that's an easy one, Vic. You put the torque seal on, and overnight the bolt torques itself to the proper value.
Chris
Chris Pratt (2018 VAF DUES PAID)
RV-8 Flying, 750+ hours
N898DK
Lycoming O-360-A1A, Hartzell CS
52F (Northwest Regional, TX)
Old 12-13-2017, 04:49 PM
Alan Carroll's Avatar
Alan Carroll Alan Carroll is offline
Hi Dave,
Glad this didn't end up causing trouble. I need to check my plans but I'm pretty sure this bolt should have a castle nut and cotter pin rather than a nylock.
Alan Carroll
RV-8 N12AC
Old 12-13-2017, 06:10 PM
RVTOY RVTOY is offline
Vic
Vic, we talking about nuts and bolts or the pilot/mechanic never tightened up properly.
RVTOY
RV7A - N11RV
Kitfox 7 completed 2010. Lost in KJOA Flood. Airworthiness cert. 6/8/2018
Always an upgrade in progress.
Donated to keep forum alive.
Old 12-13-2017, 06:23 PM
Originally Posted by Alan Carroll View Post
Hi Dave,
Castle nuts and cotter pins I believe are only used on bolts that will normally rotate. The rotation on the flap bearing should only be in the bearing.
Mel?
Tom Norwood
Old 12-13-2017, 06:27 PM
Jeff A's Avatar
Jeff A Jeff A is offline
Default It should have a cotter pin.
The plans specifically call out:
AN4-11 Bolt
AN960-416 Washer
AN310-4 Nut
MS24665-208 Cotter Pin
I just replaced these the other week.
Jeff Atkinson
RV-8 #82594 Flying since May 2012
Barrett XP-360, Catto 3-Blade, Dual G3X Touch, GTN-650, VP-X
