Old 12-12-2017, 01:10 PM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
Default Tank sealant ratio needed
I need to mix up a very small amount of PPG B2
My container does not have the ratio of part A to Part B
Anyone out there know what it is?
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
[COLOR="rgb(46, 139, 87)"]=VAF= Paid up 2018[/color]
Old 12-12-2017, 01:26 PM
Larco Larco is offline
P/S 890 Class B is an aircraft integral fuel tank sealant. It has a service temperature range from - 65F (-54C) to 250F (121C), with intermittent excursions up to 275F (135C). This material is designed for fillet sealing of fuel tanks and other air- craft fuselage sealing applications. The cured sealant maintains excellent elastomeric properties after pro- longed exposure to both jet fuel and aviation gas.
P/S 890 Class B is a two-part, manganese dioxide cured polysulfide compound. The uncured material is a low sag, thixotropic paste suitable for application by extrusion gun or spatula. It cures at room tempera- ture to form a resilient sealant having excellent adhe- sion to common aircraft substrates.
The following tests are in accordance with AMS-S- 8802 Class B specification test methods.
Application Properties
Performance Properties (Typical)
Cured 14 days @ 77F (25C), 50% RH
Cured specific gravity 1.55
Nonvolatile content, % 95
Ultimate cure hardness,
Durometer A 49
Peel strength, pli (N/25 mm), 100% cohesion JRF(AMS 2629) immersion, 7 days @ 140F (60C)
(Typical)
Color Part A
Part B Mixed
Mixing ratio By weight
Base viscosity
(Brookfield #7 @ 2 rpm), Poise (Pa-s)
Black White Gray
Part A: Part B 10:100 or 1 to ten
Old 12-12-2017, 02:17 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Default By weight
Don't overlook that the 10-to-1 is by weight.
Use a digital postal scale set to grams
Rick Aronow,
A&P, iRMT
Flying 7A Slider;
RV-12 (ELSA, Dual G3X), SOLD
Highland Village,TX
Old 12-12-2017, 03:23 PM
Thanks guys
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
Old 12-13-2017, 04:24 AM
rzbill's Avatar
rzbill rzbill is offline
Or an 11 unit long balance beam with the pivot at unit 1.
Bill Pendergrass
RV-7A: Flying since April 15, 2012. 710hrs
YIO-360-M1B, mags, CS, GRT EX and WS H1s & A/P, Navworx
Unpainted, polished....kinda'
My RV Construction Page
