Old 12-12-2017, 12:35 PM
Draker's Avatar
Draker Draker is offline
Default Practice on scrap!
Reason number 148 for why you should practice learning how to use a tool (in this case a nutplate jig) on scrap rather than the workpiece:
Sometimes I make a mistake and say, "Well that happens--lots of builders learn this one the hard way". Other times I have to say, "Wow there really isn't any excuse for this. Use your head, dummy!" This is one of those times.
If you're a new builder, heed the advice constantly given here on VAF to practice on scrap first!
Old 12-12-2017, 02:19 PM
John Tierney John Tierney is offline
I have tape permanently affixed over that outside hole on my nutplate jig just for this reason. Too many extra lightening holes.
John Tierney
Salem, WI
RV-7A - Finish/FWF Kit
N70JT Reserved
Old 12-13-2017, 11:40 AM
Flyin'Bryan's Avatar
Flyin'Bryan Flyin'Bryan is offline
Default Scrap Pile
I think my scrap pile is now about 6 inches high, with all types and shapes of "spare" aluminum and steel to use for testing. This post caught my attention because I am right at that same point of needing to drill the rivet attach holes for the those nut plates in the joiner plate. I have also been debating about using my nut plate jig for this, or another method that some have used by using the actual K1100-8 nut plate as a template, with the screw inserted to hold it against the skin in the proper place.
Curious - Are you gong to make a new joiner plate? Order a new part from Vans? Check with Vans to see if you can just build on?
Bryan Raley
http://bryansrv8project.blogspot.com/
Building RV8
EAA Chapter 301
CFII/MEI, ATP
SportAir Workshop Graduate x 4: Sheet Metal, RV Building, Electrical, and Composite classes.
Tail Wheel Endorsement Completed
Empennage done, Wings in progress, N462AK reserved.
