Go Back   VAF Forums > Main > RV Building Tips/Techniques
Old 12-10-2017, 10:24 AM
jcarne's Avatar
jcarne jcarne is offline
Default TIP: Homemade angle finder inspired by Doug's Dec. 8th math question
Guys and gals, I have found myself many times without some way to measure or find an angle. I had this happen while bending the HS spars, setting hand plane blades in a honing guide, etc. There is a relative easy way to find an angle using a little math and a piece of cardboard. The process might look complicated but I assure you if you do it a couple of times it gets fast. I can do this in less than 2 minutes. This also works for an outside angle, just make your "flat area" up a bit from the bottom and draw your right triangle downward instead of up.
Perhaps there is an easier way to do this but this method has always served me well and is surprisingly accurate. Would be even better if you used metal!
Step 1 get some flat area (about 4-5 inches) and mark a 4-6" line next to it.
20171210_095448 by Jereme Carne, on Flickr
Step 2 decide on the angle you are interseted in and do some simple math.
20171210_095804 by Jereme Carne, on Flickr
Step 3 take the results from step 2 and mark it on the vertical line depicted on the right of the above picture. The results from step 2 represent the side of the triangle opposite the angle.
20171210_095743 by Jereme Carne, on Flickr
Step 4 draw a line (aka the hypotenuse of the triangle)
20171210_095907 by Jereme Carne, on Flickr
Step 5 cut out what is needed and enjoy your new tool.
angle finder by Jereme Carne, on Flickr
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Fuselage almost done
Finish kit arrived
Exempt but gladly paying!
Old 12-10-2017, 10:28 AM
Wouldn't a protractor be a bit simpler?
Old 12-10-2017, 10:31 AM
jcarne's Avatar
Mike you are correct but I don't always have one.
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Finish kit arrived
Old 12-10-2017, 10:33 AM
Neither do I, but your math makes my head hurt.....
Old 12-10-2017, 10:36 AM
jcarne's Avatar
Haha fair enough, just slam line 3 into a calculator (with whatever angle you want) and hope I didn't make a mistake.
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Finish kit arrived
Old 12-10-2017, 10:41 AM
az_gila's Avatar
az_gila az_gila is offline
Talking No head hurting involved
No need for hurting heads if you have a PC at hand....
Tan of X degrees here -
https://www.rapidtables.com/calc/mat...alculator.html
= 0.10510424 for the 6 degrees quoted
Multiply by the baseline you want to get the size of the angle template you want, 4 inches in the case above.
0.10510424 x 4 = 0.42041696
Measure on the cardboard template to whatever accuracy you want.
No mathematical headaches involved. Simply quick and easy.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 12-10-2017, 10:49 AM
jcarne's Avatar
Thanks for the added reference to the calculator Gil!
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Finish kit arrived
Old 12-10-2017, 10:55 AM
ryschneider ryschneider is offline
Jereme, thanks for the refresher although I haven't needed to use it in a long time, I had nearly forgotten about SOH CAH TOA from Trigonometry.
Ryan
RV-7 (in progress)
N-8251F
'17 Dues paid
Old 12-10-2017, 11:20 AM
jcarne's Avatar
No problem Ryan, anytime I can teach a bit of math (especially when it applies to something) is a good day.
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Finish kit arrived
Old 12-10-2017, 11:24 AM
scsmith scsmith is offline
Not neessarily. With a protractor, your accuracy is limited by the size of the protractor, and your ability to set the corner point on the reference line of the protractor accurately, which is not always as clear as it should be.
With this technique, you can scale up the whole geometry so that measurement error has a smaller effect on the angle. If you need a durable angle, use some masonite or thin aluminum sheet.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 515 in 9 years (would have flown more this year if not for fire smoke)
also LS-6-15/18 sailplane
VAF donation Dec 2017
