Old 12-09-2017, 05:41 PM
bret's Avatar
bret bret is offline
Default EFII install
Just having fun on the laptop, for entertainment and not meant for instruction, new parts on an old engine. I was trying to document the build but got overwhelmed when I discovered there are over 2000 pics should have started on the emp but that was boring, so Ill do it like Star Wars...backwards.
https://www.youtube.com/watch?v=iwClfjYzJd0
2018 gladly supported
Old 12-10-2017, 08:04 AM
Bret---some very nice work there!
Tom
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 12-10-2017, 09:26 AM
BCP Boys's Avatar
BCP Boys BCP Boys is offline
Very impressive !
Amir
RV-7 QB - N174WM
Supporting VAF since the first visit
Old 12-10-2017, 09:54 AM
johnbright's Avatar
johnbright johnbright is offline
Default mixture knob
Sweet!
But aren't the knobs supposed to be ordered left to right throttle, prop, mixture? 23.777 D https://www.gpo.gov/fdsys/pkg/CFR-20...-sec23-777.xml
Anyway, the mixture knob... shouldn't it be somewhere on the instrument panel where it won't get bumped? EFII and SDS both recommend this and I know of an instance where the pilot knocked it full rich and stopped the engine in flight.
John Bright, RV-6A 25088, at FWF
O-360, 8.5:1, vert sump, SDSEFI EM-5
Dual alt, single batt. Wiring and IP CAD files here
Newport News, Va
Old 12-10-2017, 12:52 PM
bret's Avatar
Originally Posted by johnbright View Post
Sweet!
Supposed to? as in certified aircraft? Never thought about the certified aspect of the control location, only what felt right for me. If I ever sell I guess they can drill a hole and put it where they want, this is where I wanted it and works well there, the location just flows better for me with the pre landing check list, Thanks for the heads up on the instance you noted above, I'll investigate that possibility and see if it applies to this setup. Thanks
Old 12-10-2017, 12:57 PM
bret's Avatar
Tom
Thanks Tom, if I ever do this again I will have you make my lines, it was way more work than I anticipated.
Old 12-10-2017, 08:20 PM
Bluelabel's Avatar
Bluelabel Bluelabel is offline
Looks good man! Nice work.
Based on experience, I do agree that that location for the mixture nob might not be ideal. Obviously you can do what you want, but the reality is, once you get things dialed in, you won’t touch it much. Just my 2cents
John Walker
RV-10 N265WD
"Miss Whiskey Delta"
BPE IO-540, FULL EFII
KMYF, San Diego, Ca.
KEOS, Neosho, MO
Crew Lead on the
Grove Aero Super Legacy Reno Racer,
twin turbo, IO-540,
full EFII management system
"so I got that going for me... which is nice."
2017 Dues Paid"
