Old 12-06-2017, 10:15 AM
jonweisw jonweisw is offline
Default Oil in weird spot in cabin
Noticed a couple drops of oil underneath the throttle cable where it meets the throttle lever in the cabin. In my RV-8, I have the side panel throttle quadrant mod, but for purposes of this discussion should be considered identical to a stock build.
The other end is connected to a Lyc IO360M1B. The end of the cable is in the vicinity of the low pressure oil return lines, so I decowled to investigate. There was a touch of moistness in that area but nothing more than usual, and certainly nothing obvious that caught my eye. I tightened the hose clamps and buttoned everything up.
Any thoughts? Am I missing something? I checked the other two cables - prop and mixture - and they are completely dry (none of them are in the vicinity of any moistness anyway).
Finally, do any of you replace those short runs of hose from the aluminum return lines to the case?
Here are some pix:
[/url]
[/url]
[/url]
MANY thanks in advance.
Jon Weiswasser
N898JW, RV-8
Old 12-06-2017, 01:20 PM
airguy's Avatar
airguy airguy is offline
Any chance it could be brake fluid? I had an occasion once where I climbed to high altitude and a bubble in my brake lines burped out the reservoir, spilling a bit on the firewall. A few drops followed the brake line through the firewall where the reservoir penetrates it, and followed the line down to the right side master cylinder, where I observed it and thought I had a leaking master cylinder.
Greg Niehues - VAF 2018 dues paid
Garden City, TX
N16GN flying! http://websites.expercraft.com/airguy/
Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 12-06-2017, 03:41 PM
nope... pretty clearly motor oil.
Old 12-07-2017, 05:14 AM
rv8ch rv8ch is offline
Default A Prank?
A buddy playing a prank on you? I have "a friend" that used to do this from time to time with various mechanical devices of mine. It was really funny!
Mickey Coggins
http://rv8.ch
Old 12-07-2017, 07:45 AM
Lol. No prank.
Old 12-07-2017, 08:04 AM
jliltd jliltd is offline
Jon,
I can't tell by looking. Especially on my cell phone. Do you have an electronic oil pressure gauge with remote sender? Or rather does your oil pressure line come through the firewall to the gauge?
Jim
RV-3B
Old 12-07-2017, 11:31 AM
It's electronic (g3x) with a remote sender. the drops on the floor on the left are directly under the throttle cable termination where it joins the lever. the cable housing itself is a little moist with oil, so I don't think that its coming from somewhere else...
Old 12-07-2017, 11:51 AM
9GT's Avatar
9GT 9GT is offline
May be capillary action or high pressure bringing it in from the FWF portion of the cable? Oil leak somewhere on the engine and it collects on the cable or sheath in the high pressure area FWF and capillary action or high cooling air pressure pushes it through the cable channel into the low pressure area in the cabin?
David C.
Howell, MI
RV-9A: Under Construction
"Donor Exempt" but donated through Dec. 2018
Old 12-07-2017, 02:10 PM
airguy's Avatar
Or the cable itself got (over)oiled at some point?
Garden City, TX
Old 12-07-2017, 03:08 PM
Yeah - thats my working hypothesis. It is routed and terminates in the area just inside of the induction tubes, between the tubes and the case and bounded at the top by the cylinder and the bottom by the oil pan. Ending there, it actuates a bell crank which then moves the throttle body arm (Van's design for an IO360M1B). I believe that oil oozing through those cheap, short, runs of automotive-type tubing from the aluminum part of the low pressure oil return lines to the case has wicked into the cable and through a combination of time and pressure worked itself back to the other end of the cable in the cabin.
