Old 11-21-2017, 07:12 PM
AX-O's Avatar
AX-O AX-O is offline
Default Looking for help setting up O2 with my jet mask
All,
I am trying to figure out how to integrate my MBU-12 O2 mask into my oxygen system in the RV. I already use the standard HGU-68 helmet but would also like to implement the mask/Comm. If you have done this or know of a place that I can look into, I would appreciate it. Forced O2 not required.
Thank you for any help.
Axel
RV-4 fastback thread and Pics
West Coast Ravens
VAF 2017 paid VAF 704
The information that I post is just that; information and my own personal experiences. You need to weight out the pros and cons and make up your own mind/decisions. The pictures posted may not show the final stage or configuration. Build at your own risk.
Old 11-21-2017, 08:19 PM
salto salto is offline
Seriously!
Kit 140241
Tail Feathers done
Fuselage kit completed.
wings almost complete.
Flaps and ailerons done.
Canopy next. Phew!
Old 11-21-2017, 09:27 PM
AX-O's Avatar
Originally Posted by salto View Post
Seriously!
Yes.
Extra words
Axel
West Coast Ravens
Old 11-21-2017, 10:41 PM
G-force's Avatar
G-force G-force is offline
Perhaps check with Gibson and Barns? Things like the exhalation valves and such my not work without a pressurized system.
Mike Sumner
Castaic, Ca
Old 11-22-2017, 12:52 AM
Dave_Boxall Dave_Boxall is offline
The MBU-12 is designed for a demand oxygen system (like a scuba mask), not a constant flow system as most GA aircraft use. Demand systems use a LOT of oxygen, up to 25 litres/ minute compared to 2-4 on a constant flow system, and less on a pulsed system.
It'd be a major project to run this mask as a CF system, particularly testing/ verification.
Dave Boxall
RV-9A / Wilksch WAM-120 diesel. Flying since April 09
Bath England
=VAF= membership dues paid April 2017
Old 11-22-2017, 01:04 AM
larosta larosta is offline
You might want to give the guys over at Human Systems near your facility a call.
FlightHelmet.com has a lot of parts ant they might be able to help. You can also pick up that g suit and ejection seat that you have always wanted.
http://www.flighthelmet.com/
-larosta
Old 11-22-2017, 07:37 AM
Saville's Avatar
Saville Saville is offline
I have interest in doing this as well although it's with an MS-20001 and also an A-14. These are Korean War and WWII masks.
The valves are no longer made for these masks and I don't trust old ones. Neither are the metal connectors made. So any system would have to circumvent that whole setup. Plus it uses too much O2 as people say.
So what I was wondering is:
What would be the available O2 at your nose if you ran a modern small flexible hose up through the large mask hose and then placed the cannula across the mask roughly under your nose?
Would you get enough O2? The two outlets of the cannula are not necessarily positioned where they would be if you wore it as designed - maybe an inch away. But then you have the enclosure of the mask to trap unused O2.
But then you are also exhaling through the mask which blows both exhalent and unused O2 out the mask. You can remove the valves so that there's a clear path out.
Flying RV-8 N880BC
Double the 2017 Dues - happily paid.
Old 11-22-2017, 12:49 PM
azonic75 azonic75 is offline
Default Someone who will know
Elliot Seguin would know. He uses the set up you are looking for. Don't have his contact info He hangs around Mojave. Share what you find out
kai
RV-8a Flying
RV-10 Building
J-5A Flying
Extra 300 flying
Old 11-22-2017, 01:15 PM
n981ms's Avatar
n981ms n981ms is offline
Maybe someone with a pulse oximeter could test nasal cannula vs mask with nasal cannula in it as described above.
I suspect it will work better than nasal cannula alone.
Maxwell Duke
Kitfox S6/TD/IO240/SteamIFR Built it
RV10 IO540/AFS5600x3 Bought it
CH750 O200/AFS5500. Built it with 7 friends. DAR-Vic Syracuse
Maule M7-235C Sold it(kind of miss it)
VAF paid 5/2017
Old 11-22-2017, 02:54 PM
Saville's Avatar
I've got a PO. I've been trying to think of a suitable ground and flight test.
Take PO reading without mask
Put mask on, turn on O2, Take PO readings a (?) intervals.
If that's safe then I would take it up to (?) feet and run the same test.
Flying RV-8 N880BC
