Old 10-31-2017, 08:06 PM
J_Turner J_Turner is offline
Default N377JT
I think I'm in the 90% there and 90% to go stage. Here is access to my build pictures... https://www.icloud.com/sharedalbum/#B0W5oqs3qGwQXLs Need all of the critique I can get. I'm using two G3X touch screens, A GTN750, and a VPX pro. Remote mounted 2nd radio and transponder. Engine is a Superior IO400 and prop is a 3 blade MT. I'm working on fiberglassing in the tips on the elevator and rudder now. Let me know what you think...
Jamie
Old 10-31-2017, 10:07 PM
ColoCardinal's Avatar
ColoCardinal ColoCardinal is offline
Looks real nice Jamie. We're at about the same point (the I hate fiberglass stage). I started with the dual G3X and stayed with it instead of moving to the "touch" model. Looks as though you have an 'army' working on it so you should be done and flying soon. Keep up the good work.
Carl - - Morrison, CO
Inspection is weeks away.
Garmin fiasco is over.
paid 'til 10-18
Old 11-02-2017, 09:16 AM
smokyray's Avatar
smokyray smokyray is offline
Default Not quite....
Originally Posted by J_Turner View Post
I think I'm in the 90% there and 90% to go stage. Let me know what you think...
Jamie
Jamie,
Not quite. When you get it flying, that's the REAL 90% done, 90% to go stage...trust me
Looks good so far. My 2 cents after 25 years, 2 RV's and an HR2, keep it simple, cheap and light.
The lighter they are, the better they fly...
And...the less stuff to break, the happier you (and your wallet) will be.
V/R
Smokey
Old 11-02-2017, 12:06 PM
Raymo's Avatar
Raymo Raymo is offline
You are about where I was 2 years ago. I built almost every weekend and vacation day available. First flight was 27 January this year and I still have a large list of things to get done, as Smoky eluded.
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
Old 11-02-2017, 03:10 PM
bob888 bob888 is offline
Default Not sure why the 750
With 2 G3X screens you will not likely need the big screen on the 750; I have the 650 feeding the G3X and really never need to look at the GTN. Save some $...
Old 11-02-2017, 03:29 PM
Smile I kinda like the fiberglass part of it......
Thanks Carl, The fiberglassing really isnt that bad. Yesterday, I got both horizontal stabilizer tips and the vertical stab glassed in. Today I put a bunch of epoxy and 410 fairing filler on it. I'll sand it out tomorrow and see how it looks. As for the "army" of people working on it, that was just one day when my brother and a friend helped me. 99% of the time its me, myself, and I.
Vaf dues paid 10/17
RV-7 G3X Touch GTN 750
Superior IO400 MT 3 Blade
Old 11-02-2017, 03:32 PM
Originally Posted by smokyray View Post
Jamie,
V/R
Smokey
You're probably right!
As for the weight, I'm pretty much committed to what I have now as far as the engine, prop and such.
Vaf dues paid 10/17
Old 11-02-2017, 03:36 PM
I can usually spend 3-4 hours a day on it, quite a bit more sometimes. I really hope I can fly it this coming spring but, we'll see what happens. No need to rush anything at this point of the build.
Vaf dues paid 10/17
Old 11-03-2017, 06:38 PM
Default Fun with fiberglass
Today I got the Vertical and horizontal stabilizer tips sanded down. Need to fill some pin holes or I just may let the painter do it. Also got the bottom of the rudder glued and riveted on. Hopefully next week I can finish the rudder and elevator tips and get everything primed.
Vaf dues paid 10/17
Old 11-11-2017, 09:05 PM
Default Update
I didn't get everything in primer this week but came close. I got everything sanded down on the elevators, horiz. stab, rudder and vertical stab. Sprayed some primer on the right stab and elevator first just to see what it looked like.... Needed a little more filler and some glazing putty. Sanded it down and shot some more primer on it. Looked pretty good. Pictures on my icloud dated 11-10-17. Next week I'll try to get the rest of the tips in primer.
Vaf dues paid 10/17
