Old 10-27-2017, 10:44 AM
rwarre rwarre is offline
Default Navworx AD
Information I found out about the AD if anyone is interested. The AD Number is 2017-11-11. The following is a portion of the AD.
(e) Required Actions
(1) Within 6 months, comply with either paragraph (e)(1)(i), (ii), (iii), or (iv) of this AD:
(i) Remove the ADS-B unit.
(ii) Disable and prohibit use of the ADS-B unit as follows:
(A) Pull and secure the circuit breaker and disconnect the internal GPS antenna connector from
the ADS-B unit and secure.
(B) Install a placard in view of the pilot that states “USING THE ADS-B SYSTEM IS
PROHIBITED.”
(C) Revise the Limitations section of the Aircraft Flight Manual supplement (AFMS) by
inserting a copy of this AD or by making pen-and-ink changes to add the following: “USING THE ADS-B SYSTEM IS PROHIBITED.”
(iii) Revise the software so the ADS-B unit broadcasts a SIL of 0.
(iv) Couple the ADS-B unit with an approved external GPS as follows:
(A) Interface the ADS-B unit with an Accord NexNav mini LRU GPS Receiver P/N 21000. (B) Revise the Limitations section of the AFMS by inserting a copy of this AD or by making
pen-and-ink changes to add the following: “OPERATION USING THE INTERNAL POSITION 15
SOURCE IS PROHIBITED. USE OF THE ACCORD NEXNAV MINI P/N 21000 EXTERNAL POSITION SOURCE IS REQUIRED.”
(2) After the effective date of this AD, do not install an ADS-B unit Model ADS600-B P/N 200- 0012, Model ADS600-B P/N 200-0013, or Model ADS600-EXP P/N 200-8013 on any aircraft unless you have complied with the requirements of paragraph (e)(1)(ii), (e)(1)(iii), or (e)(1)(iv) of this AD.
(f) Alternative Methods of Compliance (AMOCs)
(1) The Manager, Fort Worth Aircraft Certification Office, FAA, may approve AMOCs for this AD. Send your proposal to: Kyle Cobble, Aviation Safety Engineer, Fort Worth Aircraft Certification Office, Rotorcraft Directorate, FAA, 10101 Hillwood Pkwy, Fort Worth, TX 76177, telephone (817) 222-5172, email kyle.cobble@faa.gov; or Michael Heusser, Program Manager, Continued Operational Safety Branch, Fort Worth Aircraft Certification Office, Rotorcraft Directorate, 10101 Hillwood Pkwy, Fort Worth, TX 76177, telephone (817) 222-5038, email michael.a.heusser@faa.gov.
(2) For operations conducted under a 14 CFR part 119 operating certificate or under 14 CFR part 91, subpart K, we suggest that you notify your principal inspector, or lacking a principal inspector, the manager of the local flight standards district office or certificate holding district office before operating any aircraft complying with this AD through an AMOC.
Old 01-03-2018, 07:21 AM
MS19087's Avatar
MS19087 MS19087 is online now
Angry NAVWORX AD - removal date?
Can’t find the information on the date in which I must remove my existing effected unit from operation. I think it is sometime in Jan 2018. Anyone have that date?
RV-9A; IO-320 w/ Whirlwind WW-151
(Flying since June 2011)
RV-14A; tailkit
2019 =VAF= donor
Old 01-03-2018, 07:59 AM
Super Moderator
Default January 11, 2018
The AD states that we must comply within 6 mos of the date of the AD, which was July 11, 2017, so that means January 11, 2018.
Here's the link to the AD:
https://www.gpo.gov/fdsys/pkg/FR-201...2017-11625.pdf
Vic
Vic Syracuse
Van's East Coast Representative
www.Baselegaviation.com
Old 01-03-2018, 10:49 AM
rleffler's Avatar
rleffler rleffler is offline
Vic
Or implement any of the approved AMOCs, which are being distributed on AOPA's web site. In additional to the original three, there are two new ones in process. One for the EXP and one for Avidyne as a position source. Mike should have those up on the AOPA site shortly.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 01-03-2018, 11:01 AM
tim2542 tim2542 is offline
Bob what do you know about the EXP AMOC? Should I get my hopes up?
I have a Echo sitting here to put in, but reading other posts here on VAF it sounds like it doesn't filter traffic as well as the Navworx unit, or accept baro serial data.
Darn shame to remove it, works so well for me.
Tim Andres
Old 01-03-2018, 11:37 AM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
Tim Andres
EXP AMOC has been approved.
Info can be found on this thread, post 27
http://www.vansairforce.com/communit...hlight=Navworx
The AMOC instructions reside here:
http://www.zenith.aero/profiles/blog...-compliance-di
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1095+ hours
2018 Donation Paid
Old 01-03-2018, 01:19 PM
Thanks but...
That only converts it to a receiver. I was hoping those guys had cracked the code so we could feed gps info to it, like from a 430 etc.
Tim Andres
Old 01-03-2018, 04:20 PM
Thanks but...
Tim Andres
No. I doubt that will ever happen & get approval. I would think that the firmware would need to be updated & Navworx no can do.
At this point, it sounds as though the Navworx receiver is doing a better job than some other solutions. This way, we might only need an OUT solution for the short term.
1095+ hours
2018 Donation Paid
Old 01-03-2018, 06:48 PM
dtw_rv6 dtw_rv6 is offline
Yeah - it isn't too hard to inject a new GPS signal in place of the one on the circuit board, but I haven't figured out how to test it's ability to report any integrity issues that a replacement GPS would have to provide. Unless we get a copy of the firmware (that is encrypted on the board), a hardware change won't do any good.
Don
