Go Back   VAF Forums > Main > My RV Build Project
Old 10-16-2017, 01:57 AM
Tdeman's Avatar
Tdeman Tdeman is online now
Default RV-6 (previously 7) "After-Midnight Aircraft Factory"
Hey guys, first time (aircraft) builder who finally has enough progress to show something off! Initial progress was slow due to buying/making tools as needed, however it has sped up recently. Most building time has been late in the evenings after class, work, and assignments, but I've been doing what I can this last (busy) semester!
IMG_6918 by Taylor de Man, on Flickr
IMG_7168 by Taylor de Man, on Flickr
IMG_7221 by Taylor de Man, on Flickr
IMG_0040 by Taylor de Man, on Flickr
IMG_7225 by Taylor de Man, on Flickr
IMG_7227 by Taylor de Man, on Flickr
IMG_7230 by Taylor de Man, on Flickr
IMG_7233 by Taylor de Man, on Flickr
Rudder is now ready for leading edge rolling, fiberglass, and a few rivets in hard to reach spots... That'll be waking the neighbors this week!
This post brought to you in part by, pour-over coffee, sleep deprivation, and a need for speed.
Old 10-16-2017, 03:18 AM
74-07 74-07 is offline
Awesome work!
Old 10-16-2017, 06:03 AM
petehowell's Avatar
Default Looking Good!
I started my -9A when the kids were little and the deal with the spouse was that it could not take time away from the kids. Most of the plane was built from 10pm-1am in the garage.
Important safety tip - set an alarm to go to bed! More than once I was having so much fun, I went in the house to find it was 3 am and almost time to get up for work!
Pete
Amateur Plane - RV-9A N789PH - 1950+ Hrs
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 10-16-2017, 06:08 AM
mturnerb mturnerb is online now
Impressive work!
Sleep is for wimps anyway....
Turner Billingsley
RV-14A In Progress
N14TK Reserved
Old 10-16-2017, 06:54 AM
grubbat's Avatar
grubbat grubbat is offline
Default Rudder
Is your rudder the -6 or the -8?
Looks like you are doing a fine job.
Cj
Craig
RV-3 Sold
RV-6a Sold
RV-9 IO-360 CS, Flying
1967 Twin Comanche C/R, Flying......
Old 10-16-2017, 10:14 AM
Tdeman's Avatar
Thanks for the positive feedback guys!
Cj
Good catch! The rudder being built is the RV-8 rudder (the one originally used on the RV-7). I'm planning on a bit of a hot-rod build, hence my choosing this particular rudder to use.
Old 10-16-2017, 11:18 AM
slngsht slngsht is offline
Originally Posted by mturnerb View Post
Impressive work!
sleep... the reason we have autopilot
Old 10-16-2017, 01:28 PM
Tdeman's Avatar
I wonder if anybody would notice a few missing FANUC robotic arms from the lab on campus... I could have them run the day shift!
Old 10-16-2017, 08:29 PM
jcarne's Avatar
jcarne jcarne is offline
Work is looking good so far, great dimples and rivets. Just a question/thought though; it looks like you are priming the internal parts including the skins but I noticed that you have the red lettering bleeding through the primer. Normally the parts are cleaned of oils and dirt using an acetone soaked rag after scuffing (which also removes that red lettering) as primer adhesion in these areas would eventually most likely become compromised. Maybe the skins aren't primed and it's an illusion in the pic though, just wondering.
Jereme Carne
PPL
RV-7A Emp. coming along
Working on Wings
Exempt but gladly paying!
Old 10-16-2017, 09:29 PM
Tdeman's Avatar
I've been scuffing lightly with scotchbrite, then using a damp rag, followed by a rubbing alcohol-soaked rag to remove debris/grease. The alcohol doesn't seem to cut the red lettering as hard as acetone would, however an extra pass or two does in fact remove it.
Perhaps I should switch from alcohol to acetone?
