Old 10-07-2017, 10:36 PM
mfleming's Avatar
mfleming mfleming is offline
Default Baja Designs LED in Duckworks Assembly
Well I know this has been done before but I thought I'd share my version of this install.
Previously I had installed the Duckworks leading edge landing light kit. Not knowing exactly which lamp assembly I was going to install, I bought the Blank Lampless Install Kit.
So I decided to install a taxi light in the leading edge and a landing light in each wingtip.
The taxi light is the Baja Designs Squadron Sport Flush Mount Driving/Combo. This is a 20 watt 1.4 amp unit.
The landing lights will be the Squadron Pro, Flush Mount, LED Spot Those units are 40 watt 3.33 amps.
Here are some photos of the taxi light install:
Finding the center of the opening.
The Duckworks bracket with the template laid out.
Here is the BD combo installed.
Here's the backside...very simple install.
Although this is probably not a very good representation of the light...I couldn't resist checking it out.
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Donated 2017
Old 10-08-2017, 07:35 AM
Looks great.
But if your build doesn't even have the leading edge riveted on yet, by the time you fly there'll be a light that actually supplies power instead of drawing it....
Old 10-08-2017, 08:21 AM
Bavafa Bavafa is offline
Smile
Originally Posted by rv7charlie View Post
Looks great.
I have been waiting for that light and hoping not to invest in an alternator, only the light alone
Mehrdad
RV7A - IO360M1B - SOLD
Dues paid
Old 11-08-2017, 12:56 AM
Draker's Avatar
Draker Draker is offline
What are the approx. dimensions of the cut-out template? I went and got the "round hole" Duckworks kit because I didn't know which lighting option I'd go with and figured most lights are round. Wonder if I decided to go with the Bajas whether I could still use the kit with the round hole and trim around it...
Old 11-08-2017, 10:26 AM
mfleming's Avatar
Yes! You can use your round hole Duckworks bracket
Here's a VAF thread on putting the Baja light in a round hole Duckworks fixture. Bruce uses the same flush mounted light that I used.
If you still need some numbers, I'd be glad to go out to the shop and do some measuring
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Started 11/2016
Donated 2017
Old 11-08-2017, 12:47 PM
Draker's Avatar
Thanks, Michael, that link was exactly what I was looking for. Wonderful!
