Old 10-06-2017, 07:07 AM
JPalese's Avatar
JPalese JPalese is offline
Default RV-12 Fuel Cap Vent
Does anyone have the drawings of how to vent the fuel cap?
My recollection is it used to be in KAI 37 but I can't find it there any longer.
Old 10-06-2017, 07:23 AM
rgmwa rgmwa is offline
The cap itself is no longer vented. There is a separate vent line from the tank as per KAI 37.
rgmwa
120346
Old 10-06-2017, 06:49 PM
scottmillhouse's Avatar
scottmillhouse scottmillhouse is offline
Drill the vent hole anyway in the cap. You need it with a full tank on takeoff. Obviously fuel blocks the new vent and fuel pressure goes down which is kind of scary on a take off. It will stabilize when you level out and burn fuel. There is no problem with the cap vented too.
Scott- 2018 dues paid
Got medical back, now building a 7A.
RV-12 #120515, 319RV over 200 hours.
1st flight 12/08/15, flew SNF, Oshkosh, Triple Tree & SERFI in year 1!
RV-9A, 536 hours, sold, RV-7 sold, Kitfox sold
Old 10-06-2017, 08:07 PM
tomkk's Avatar
tomkk tomkk is offline
First time I've heard of this - I've never seen ithappen in my -12 ...
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845
First flight 06/10/2015
Old 10-06-2017, 08:30 PM
MMiller MMiller is offline
John, you remember correctly, but the step was removed with the 12/27/2013 revision that added a fuel tank vent line.
Here is screenshot of the relevant instructions from a 2011 version of section 37.
Old 10-06-2017, 08:39 PM
Even if the fuel tank is so full that gasoline fills the vent line, the fuel pressure at the bottom of the tank will be higher than when the tank is not quite so full. That statement can be proven with a manometer.
Joe Gores
RV-12 Flying
Old 10-06-2017, 08:51 PM
DBRuth DBRuth is offline
Default Cap vent
I drilled the vent hole slightly smaller than the plans called for, tap drill size for a 4-40 tap. Then I tapped both holes. If you don't like the results of the new vented cap, you can put a 4-40 screw in one of the holes. YMMV
N412DR
Kit 120797
First flight 8/21/15 what an awesome aircraft!
HOBBS @129.3
Old 10-06-2017, 10:38 PM
JPalese's Avatar
Default Thank you - Exactly what I was trying to find!
Thanks to all for your replies.
Old 10-07-2017, 09:33 AM
On drilling the vent anyway. Based upon my experience, ever time I filled my tank to the filler neck and fuel came out the vent, the next flight I would have low fuel pressure (1-3 psi) on climb out. A year and a half and about 170 hours since I drilled the hole in the cap, I have not had a low fuel pressure problem. I see no down side on having the cap also vented unless your plane is out in the rain without a canopy cover. Also it is a back up in case the dirt dabblers like your fuselage vent.
Old 10-07-2017, 09:25 PM
The only time Iíve had insect problems was on another home built I had. Something took up residence in my pitot tube. Became pretty obvious on takeoff roll when the airspeed never cam alive. It was a pain to disassemble the hose fitting and blow out he tube because I had a hard time getting to fitting tomreseal.
