Old 09-10-2017, 05:46 PM
rgmwa rgmwa is offline
Default Radio issues (RV-12)
I'm trying to track down a transmit issue with the SL40 and Flightcom 403 intercom in my RV-12. My radio installation has never worked particularly well, and initially had a loud squeal until I adjusted the SL40 settings as others have previously posted, so I know they are OK. However every time I press the PTT button, I get a loud steady tone in the headset (sidetone?). It is possible to hear voice over the tone on a nearby handheld radio, but the reception is pretty bad, and in the air is reported as unreadable. This happens even with just the master and radio on and everything else off. My mic jack has isolation washers on it as per the plans, and both pilot and co-pilot sides have the same problem. Swapping headsets makes no difference. It was suggested the problem may be in the 403 rather than the SL40. Pilot/passenger conversation works OK. The problem only occurs when the PTT button is pressed. Any ideas?
rgmwa
120346
Old 09-10-2017, 07:04 PM
Most likely not your problem but might want to look here... http://www.vansairforce.com/communit...&highlight=403
Also, check radio problems on page 10 here...http://vansaircraft.com/public/RVato...009-RVator.pdf
Hinckley, Ohio
EAA #499867
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 406
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 09-10-2017, 08:17 PM
Thanks Jim. In my case I can receive transmissions OK and voice gets out when I transmit, but the steady loud tone that I hear when I press the PTT button also seems to get transmitted and pretty much masks the voice. My jacks are as per the plans, so they should be OK.
rgmwa
120346
Old 09-10-2017, 09:18 PM
Try removing the radio antenna, cleaning the both the antenna base and the fuselage skin to make sure there is good metal to metal contact when it is reinstalled. Also check the coax cable at each end.
Make sure the radio is FULLY seated in its rack.
Joe Gores
RV-12 Flying
Old 09-10-2017, 09:35 PM
Thanks Joe. I'll try that. The plane is due for its annual (again!) in a week or two, so it will be a good time to take things apart.
rgmwa
120346
Old 09-11-2017, 05:15 AM
noelf noelf is offline
You could try removing the power wire that powers the 403 intercom. This will "activate" the failsafe feature of the intercom and connect the pilots headset directly to the radio. This should completely bypass the intercom unit.
Noel
RV-6A N6NF
tip-up
flying
Old 09-11-2017, 06:14 AM
That sounds like a good idea. Thanks Noel.
rgmwa
120346
Old 09-11-2017, 09:50 AM
hthaman hthaman is offline
Dynon radio can be installed on a ELSA ?
Old 09-11-2017, 04:59 PM
Yes, but only after certification in the US (or with Van's approval). My 12 is EAB anyway (or AB(E) as it's known here), so no problem.
rgmwa
120346
Old 09-13-2017, 05:42 AM
todehnal todehnal is offline
Hey Robert, did you find the cause of your squeal?
Tom
2013- RV12, Kit #119. N123M First flight Nov21. It's a keeper!
1998- RV-9 tail kit, built and sold
1989- RV-6 tail kit, built and sold
