Old 09-06-2017, 11:55 AM
Default WEIGHT AND BALANCE
I did the weight and balance on the RV14 today. Dead calm air allowed me to do the job outside which is very nice. The aircraft came in at 1227 lbs which is 13 lbs less then the factory specs. Final paint will add a few pounds but we are in the right ball park. I really like to fly the plane for a year or so to get all the bugs out of it before final paint. This allows you to make changes without the worry of ruining an expensive paint job.
It is great to get to this stage, the building is done! Now on to paperwork, final inspection and a few hundred screws to install!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger flying #153
Fairlea Field
fairleafield@gmail.com
Old 09-06-2017, 12:16 PM
bkervaski's Avatar
Awesome! Can we see some cabin pics???
Progress: Away for PAINT
Old 09-06-2017, 01:23 PM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
You mind sharing your c.g.? Also any mods to the plans for weight reduction or c.g. changes?
Rob Lasater
Rv-14 emp/fuse done working on wings and finish
Paid dec 2017
Old 09-06-2017, 02:52 PM
No real mods for weight reduction, other then light interior paint, no side panels, carpet etc.
The C of G worked out as Van's suggested, and with a gross weight of 2050 you can have 250 pilot, a 159 pound passenger and 100 pounds of gear with full oil and full fuel (300 lbs) and be within aft C of G limit. As you burn fuel to a minimum of 30 pounds, this shifts the c of g further back to close to, but within, aft limits.
Forward C of G is limited to a minimum 75 pound pilot, no baggage and low fuel.
I feel this means a success in the load department and should make it a very versatile aircraft.
CPL & IFR rated
Fairlea Field
Old 09-06-2017, 06:22 PM
Bevan Bevan is offline
Wouldn't the forward CG limit be tested with full fuel?
Bevan
RV7A Flying
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 09-06-2017, 07:33 PM
Right you are! I played with the spreadsheet to get the exact minimum pilot weight for a maximum fuel weight of 300 lbs. As you burn fuel the c of g goes aft
with full fuel you would need a pilot with a minimum weight of 69 pounds to be at the exact forward limit.
CPL & IFR rated
Fairlea Field
