Old 08-03-2017, 02:39 AM
Peter Costick Peter Costick is offline
Default Fitting the wings...fuel tanks on or off?
Just looking for views.....
I am about to attach the wings for the last time (I hope). Currently the tanks are off of the wing and I am wondering if its best to fit the wings and then the tanks.... or the other way round.
thanks
Peter Costick
Melbourne Australia
RV7A, VH-SVN
2018 Donation Made
Old 08-03-2017, 09:06 AM
pilotkms pilotkms is offline
I did it with tanks on and all is well. There's probably someone that did it with tanks off and they'll tell u it came out fine too. But I'll leave that for them. Seems more intuitive to have the tanks on for the final assembly. but I don't see/know the circumstances u are dealing with.
Keith
RV 7A RV #9700
N325KS the Flying K
Built in SoCal KCCB, now @ KPXE
120 Hours in Year 1 & 4x cross the USA
2018 OSH - yes
Old 08-03-2017, 09:14 AM
Raymo's Avatar
Raymo Raymo is offline
Also fitted mine with tanks on but not all the screws installed. If I recall, you need to fit the fwd tank bracket as part of the process.
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
Old 08-03-2017, 01:04 PM
Bevan Bevan is offline
I installed the wings first, then added the tanks. The advantages were less wing weight to handle, and being able to hold the inboard wing right at the spar (almost CG of the wing). Installing the tanks later was no problem.
Bevan.
RV7A Flying
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 08-03-2017, 01:32 PM
Bavafa Bavafa is offline
You are going to need to finish the front attachment point which requires to have the tank on so it does not make sense (to me) not to do it with the tank on. While you are at it, you may want to finish the gear leg fairing (if it is a 7A) so you are done with this portion of the project.
My 2 cents only
Mehrdad
RV7A - IO360M1B - SOLD
Dues paid
Old 08-03-2017, 01:50 PM
Simon Hitchen Simon Hitchen is offline
Default Tanks on
Did mine a few days ago with the tanks on. No problem at all
Simon Hitchen
Port Perry, ON, Canada
7 Tip Up, Titan XIO-360, Sensenich FP Prop, Dynon Skyview, GTR-200, GTX-327
FLYING!
Old 08-04-2017, 06:53 AM
219PB 219PB is offline
I did mine with the tanks on but in hindsight if the tanks are already off leave them off. This allows you to stand right by the spar and guide it in. The tanks can then be installed and fit the forward bracket. The wings are not overly heavy, just bulky.
Paul Bonorden
RV-6A under construction
My Builders Website
Victoria, TX
2018 Dues Gladly Paid
