Old 07-13-2017, 10:08 AM
Norcalrv7 Norcalrv7 is offline
Default New tire, new shimmy
A few days ago I replaced the nose tire and tube on my RV-7A due to a worn tube. Nose wheel has been modified by anti splat with sealed bearings, and
previously had been balanced. On takeoff roll with the new tire and tube I noticed a slight bumping during and after the ground roll. "dang" I thought to myself, new tire isn't balanced as perfectly as the old one. No big deal I thought, until I landed. Normal landing, but when I let the nose gear touch I felt a split second of shimmy, which then stopped. I went around the pattern again to confirm, and same thing happened. I've never had any shimmy at all in my airplane, guess its time to pull the tire back off and balance it.
Caleb
Flying RV-7A With SDS Electronic fuel injection
ATP CFI A&P
Based at EKA, Northern CA
Old 07-13-2017, 10:18 AM
Raymo's Avatar
Raymo Raymo is online now
Did you re-check the nose wheel break-out force?
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 07-13-2017, 10:23 AM
PerfTech's Avatar
PerfTech PerfTech is offline
Caleb
....Before you remove it from your plane, give it a spin to visually check it for being round, with no more than about .060" run-out. Any more than this can cause issues. The Aero Classic tires are the worst. If you find this to be the case, remove it and send it back as defective. We return about 30% of them as unusable. The most perfectly round tire for the nose is the Ching Shin cheep tires. Also be certain the wheel halves are properly aligned with one another. I see this error all the time on Matco nose wheels when they come in for service or modification. Thanks, Allan...
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
